problem with running OpenFOAM
Like Tree1Likes
  • 1 Post By ArathoN
Old   October 15, 2014, 12:48
Default problem with running OpenFOAM
Jason
J.Y.Won is on a distinguished road
Hello everyone.
I'm just beginner of OpenFOAM.
I have a few questions.
My situation is :
I was running tutorial case (interDyMFoam/ras/DTC-Hull)
in here, I enlarged domain block and DTC hull
domain block is 100 meter for x-direction, 5meter for y direction, 10meter for z-direction.
And I run it as described in "Allrun"script.
here, i skipped toposet procedure. because I was finding what it was.
so, after I run interDyMFoam, error message was shown.
"Unable to set reference cell for field p. Please supply either pRefCell or pRefPoint"
Q1. Is this error have a relation with toposet?
Q2. Where can I find some information about toposet? I'm so curious what it is and why do this and how it works in OpenFOAM
thanks.
J.Y.Won is offline   Reply With Quote
Old   October 15, 2014, 13:34
ArathoN
ArathoN is on a distinguished road
I never done that tutorial but these values are on fvsolution, it means you have an ill-conditioned problem with no specification to the pressure so you have to set a paressure value (pRefValue) to a reference ( a cell pRefCell or a point pRefPoin).
Now I gave a glance at the standard case but the pressure field is properly defined so it shouldn't need the setting of the reference cell for p. Post you /0 folder zipped because if you changed only the mesh it should have been fine.
topoSetDict is useful to manipulate a set of cells/region of the mesh, I advice tou to read the sample file in
/opt/openfoam230/applications/utilities/mesh/manipulation/topoSet
e.g In that tutorial everytime he created a new set of cell(c0) that he refined.
J.Y.Won likes this.
ArathoN is offline   Reply With Quote
Old   October 15, 2014, 23:07
Jason
Thank you for your kind reply
For the toposetDict, I'll study the tutorial you said.
and, here, I attatched '0'zipped folder and block Mesh file.
I found that if i skip only toposet and refindmesh procedure, it works.
but after i change blockMesh and enlarge the DTC-scaled.stl 5times larger, error happens.
Many Thanks, Won.
Old   October 16, 2014, 04:32
ArathoN
you need to post the errors log too, copy and past the terminal output.
I just noticed that you heavily modified the blockMeshDict and especially the patches, you eliminated some of them. This can be the root of the problem.
Just a note I think you noted that in the BCs some patches are absent, but they are defined implicitly in the included file "setConstraintTypes".
And after reading the /0 files you got me confused, for sure you have some and a lot of errors, keep note that the number of patches declared on blockMeshDict must be the same on the /0 files You deleted some patches on blockMeshDict but you kept them in the zero folder. So modify accordingly you mesh because you didn't only enlarge it but you completely changed it, i can't help you here because paraFoam doesn't work on my machine.
Old   October 16, 2014, 11:05
Jason
Thanks.
I'll check the B.Cs and 0 Folder.
And here is my error message
in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #9 in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #9 [4] in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/interDyMFoam"
[acelab-Latitude-6430U:04980] *** Process received signal ***
[acelab-Latitude-6430U:04980] Signal: Floating point exception (8)
[acelab-Latitude-6430U:04980] Signal code: (-6)
[acelab-Latitude-6430U:04980] Failing at address: 0x3e800001374
[acelab-Latitude-6430U:04980] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f52693fc4a0]
[acelab-Latitude-6430U:04980] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f52693fc425]
[acelab-Latitude-6430U:04980] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f52693fc4a0]
[acelab-Latitude-6430U:04980] [ 3] /opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam41outletPhaseMeanVeloci tyFvPatchVectorField12updateCoeffsEv+0x22b) [0x7f526cc8464b]
[acelab-Latitude-6430U:04980] [ 4] /opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam17mixedFvPatchFieldINS_ 6VectorIdEEE8evaluateENS_8UPstream10commsTypesE+0x 3b6) [0x7f526c9dd2c6]
[acelab-Latitude-6430U:04980] [ 5] interDyMFoam(_ZN4Foam14GeometricFieldINS_6VectorId EENS_12fvPatchFieldENS_7volMeshEE22GeometricBounda ryField8evaluateEv+0x16b) [0x44f9eb]
[acelab-Latitude-6430U:04980] [ 6] /opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so(_ZN4Foam25dynamicMotionSolverF vMesh6updateEv+0x509) [0x7f526bb99f29]
[acelab-Latitude-6430U:04980] [ 7] interDyMFoam() [0x42a0d2]
[acelab-Latitude-6430U:04980] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f52693e776d]
[acelab-Latitude-6430U:04980] [ 9] interDyMFoam() [0x43689d]
[acelab-Latitude-6430U:04980] *** End of error message ***
[2] #9 [7] in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/interDyMFoam"
[acelab-Latitude-6430U:04983] *** Process received signal ***
[acelab-Latitude-6430U:04983] Signal: Floating point exception (8)
[acelab-Latitude-6430U:04983] Signal code: (-6)
[acelab-Latitude-6430U:04983] Failing at address: 0x3e800001377
[acelab-Latitude-6430U:04983] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f93ea56c4a0]
[acelab-Latitude-6430U:04983] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f93ea56c425]
[acelab-Latitude-6430U:04983] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f93ea56c4a0]
[acelab-Latitude-6430U:04983] [ 3] /opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam41outletPhaseMeanVeloci tyFvPatchVectorField12updateCoeffsEv+0x22b) [0x7f93eddf464b]
[acelab-Latitude-6430U:04983] [ 4] /opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam17mixedFvPatchFieldINS_ 6VectorIdEEE8evaluateENS_8UPstream10commsTypesE+0x 3b6) [0x7f93edb4d2c6]
[acelab-Latitude-6430U:04983] [ 5] interDyMFoam(_ZN4Foam14GeometricFieldINS_6VectorId EENS_12fvPatchFieldENS_7volMeshEE22GeometricBounda ryField8evaluateEv+0x16b) [0x44f9eb]
[acelab-Latitude-6430U:04983] [ 6] /opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so(_ZN4Foam25dynamicMotionSolverF vMesh6updateEv+0x509) [0x7f93ecd09f29]
[acelab-Latitude-6430U:04983] [ 7] interDyMFoam() [0x42a0d2]
[acelab-Latitude-6430U:04983] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f93ea55776d]
[acelab-Latitude-6430U:04983] [ 9] interDyMFoam() [0x43689d]
[acelab-Latitude-6430U:04983] *** End of error message ***
I'll modify other scripts, and run it again.
Many thanks, Won.
Old   October 16, 2014, 12:39
ArathoN
Thanks.
sorry but i can't help you here, I don't understand the error. Hope someone could help you.
Old   October 16, 2014, 14:33
Jason
OK, I'll seek a solution.
Thank for your kind advise.
Have a nice day
toposet
running OpenFoam in parallel vishwa OpenFOAM Running, Solving & CFD 22 August 2, 2015 09:53
Problem when installing Openfoam 2.0.x with mac giovaniharyadi OpenFOAM Installation 0 March 24, 2012 19:45
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
paraFoam running problem Aleksey_R OpenFOAM 2 November 27, 2009 19:18
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
