mesh storage in another directory
Like Tree2Likes
  • 2 Post By K62
Old   October 14, 2014, 11:41
Default mesh storage in another directory
K62
Martin Schmelzer
K62 is on a distinguished road
Dear all,
I study the turbulence models implemented in OpenFOAM. For this I need to run a bunch of different simulations for a test case with different settings (e.g. different coefficients), which requires a case folder structure for each simulations (0/ constant/ system/). However, the mesh is kept the same for all simulations and I don't wanna copy or rebuild it for each simulation, because it is rather expensive to do. Thus, I would like to know if you guys know a way, how to store the mesh in a something like a parent folder and link it to the folder structure of each simulation?
It should look similar to this kind of generic structure:
Simulation1/{0/ constant/ system/}
Simulation2/{0/ constant/ system/}
Simulation3/{0/ constant/ system/}
folder-containing-the-mesh-for-each-simulation/
Any help is appreciated!
K62 is offline   Reply With Quote
Old   October 21, 2014, 15:57
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
You could just use soft-links, either via the terminal or some file manager. So make the mesh once (polyMesh folder) and create soft links in all constant folders to this polyMesh folder.
Regards,
Tom
tomf is offline   Reply With Quote
Old   October 22, 2014, 05:28
K62
Martin Schmelzer
Hi Tom,
Thanks for your reply. I already figured that out, but haven't posted it yet - I am sorry!
For everybody who runs into the same problem my detailed workaround is as follows:
0. Make a backup copy of your <case> (you never know...):
cp -r <case> bu.<case>
1. Copy your <case> containing 0/ constant/ system/ and name the copy e.g. parent_mesh_case:
cp -r <case> parent_mesh_case
2. Go to parent_mesh_case and create the mesh, e.g. by running blockMesh
cd parent_mesh_case
blockMesh
3. Now go back to your <case> and delete or rename the polyMesh folder, e.g.
cd ../<case>/constant
mv polyMesh bu.polyMesh (just in case you gonna need it in the future)
4. Create a symbolic link referring to the mesh directory in parent_mesh_case
ln -s ../../parent_mesh_case/constant/polyMesh .
5. Now if you copy your <case> also the symbolic link will be copied. So you don't copy your mesh, which might be expensive, but only the symbolic link, which is cheap.
cp <case> new_case
cp -a <case> new_case (on mac)
Now, everything what you change in parent_mesh_case/constant/polyMesh is also changed in <case>/constant/polyMesh
Again thanks to Tom for reminding me posting that.
Cheers!
behnamEll and Babelus like this.
mesh, parent folder, running
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
