October 9, 2014, 11:14 |
createBafflesDict creates nfaces 0
Martin
Rep Power: 15 |
Greetings!
I have returned to do some CFD. Problem is that I need to use internal boundaries. A year ago I used this command line Code:
"createBaffles -overwrite facezone "(patch1 patch2)" Code:
baffles { baffleFaces { type faceZone; zoneName some_name; patches { master { name patch_from_some_name_1; type patch; } slave { name patch_from_some_name_2; type patch; } } } } Code:
Reading baffle criteria from createBafflesDict Not converting faces on non-coupled patches. Reading geometric fields Reading volScalarField X Created zone baffleFaces at index 6 with 120 faces Converted 0 faces into boundary faces in patches 2 ( patch_from_some_name_1 patch_from_some_name_2 ) --> FOAM Warning : From function createBaffles in file createBaffles.C at line 773 Setting field on boundary faces to zero. You might have to edit these fields. Writing mesh to 0 End Code:
patch_from_some_name_1 { type patch; inGroups 1(baffleFaces); nFaces 0; startFace 69238; } patch_from_some_name_2 { type patch; inGroups 1(baffleFaces); nFaces 0; startFace 69238; } Yours sincerely, Martin Last edited by latvietis; October 9, 2014 at 11:17. Reason: better reading |
October 10, 2014, 09:24 |
Alex
Rep Power: 22 |
Hello Martin,
First of all I'm not an expert creating baffles and I'm not aware of all the posible ways to create them, I actually created baffles only once in a case I'm currently working. This is the implementation I'm using in my case, which differs a little from yours (I don't know if yours is correct or not...): Code:
baffles { heaterBaffle1D //baffle name. Master and slave are created afterwards according to this name { //- Use predefined faceZone to select faces and orientation. type faceZone; zoneName heater; patchPairs { type wall; patchFields { #include "./0/include/wallBafflePatches_heater" #include "./0/include/1DBaffle/1DTemperatureMasterBafflePatches_heater" } } } Regards, Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
October 14, 2014, 06:00 |
Martin
Rep Power: 15 |
Thank you for responding, Alex!
Sadly this is not the solution. The problem, in my opinion, lies in creating this patch in first place. I use gmsh, my case is really simple - lets say a small box in a larger box. Each face of my smaller box is created as a physical boundary in gmsh. After using gmshToFoam I use topoSet. Lets say one of my faces is called "front_patch" in gmsh. Then I use this code to create front zone that I could use in createBaffles. Code:
actions ( //front { name front_set; type faceSet; action new; source patchToFace; sourceInfo { name front_patch; option all; } } { name front; type faceZoneSet; action new; source setToFaceZone; sourceInfo { faceSet front_set; } } ) Code:
Found boundary face (in patch front_patch) in faceZone front to convert to baffle patch front_master Run with -internalFacesOnly option if you don't wish to convert boundary faces. __________________________________________________ _______________________ Edit: I found the "solution". If anyone gets similar problem using gmsh it just might be because of incomplete meshing process. I had some small flaws in my .geo (a small nuance I had forgotten). createBafflesDict works great! Sincerely, Martin Last edited by latvietis; October 16, 2014 at 03:25. Reason: found a solution which doesn't deserve a new reply |
May 8, 2020, 06:49 |
Simon
Rep Power: 7 |
Hello everyone.
I know its a long time since the thread was started but now I have the same challange. The difference is that I am not using GMSH. What I am trying is to do is the the tutorial about 'ReactingParticleFoam' that is recommended at openfoam.com. It is only using blockMesh. If you want to see the specific files: https://develop.openfoam.com/Develop...celFoam/filter I am am trying to use the filter tutorial. I did some syntax-changes in 'topoSetDict' to run it because it seemd to be in an older version. For changed example I changed: Code:
source boxToCell; box (1.5 -10 -10) (2 10 10); Code:
source boxToCell; sourceInfo { box (1.5 -10 -10) (2 10 10); } Code:
Reading baffle criteria from createBafflesDict Not converting faces on non-coupled patches. Created zone cycLeft at index 0 with 20 faces Created zone cycRight at index 1 with 20 faces Converted 40 faces into boundary faces in patches 4 ( cycLeft_half0 cycLeft_half1 cycRight_half0 cycRight_half1 ) --> FOAM Warning : From function int main(int, char**) in file createBaffles.C at line 827 Setting field on boundary faces to zero. You might have to edit these fields. Writing mesh to 0 End Code:
baffles { cycLeft { //- Use predefined faceZone to select faces and orientation. type faceZone; zoneName cycLeft; patches { master { //- Master side patch name cycLeft_half0; type cyclic; neighbourPatch cycLeft_half1; } slave { //- Slave side patch name cycLeft_half1; type cyclic; neighbourPatch cycLeft_half0; } } } ... Code:
8 ( walls { type wall; inGroups List<word> 1(wall); nFaces 172; startFace 3294; } inlet { type patch; nFaces 20; startFace 3466; } outlet { type patch; nFaces 20; startFace 3486; } frontAndBack { type empty; inGroups List<word> 1(empty); nFaces 3440; startFace 3506; } cycLeft_half0 { type cyclic; inGroups List<word> 2 ( cyclic cycLeft ) ; nFaces 20; startFace 6946; matchTolerance 0.0001; transform unknown; neighbourPatch cycLeft_half1; } cycLeft_half1 { type cyclic; inGroups List<word> 2 ( cyclic cycLeft ) ; nFaces 20; startFace 6966; matchTolerance 0.0001; transform unknown; neighbourPatch cycLeft_half0; } cycRight_half0 { type cyclic; inGroups List<word> 2 ( cyclic cycRight ) ; nFaces 20; startFace 6986; matchTolerance 0.0001; transform unknown; neighbourPatch cycRight_half1; } cycRight_half1 { type cyclic; inGroups List<word> 2 ( cyclic cycRight ) ; nFaces 20; startFace 7006; matchTolerance 0.0001; transform unknown; neighbourPatch cycRight_half0; } ) In contrast to that the tutorial was uploaded just 4 month ago, so shouldn't it be a compatible with the latest version of OpenFOAM? What could be reasons for this? Thank you Simon |
July 16, 2021, 11:00 |
hirota tomohiro
Rep Power: 5 |
Hi Simon, did you solve this problem?
I'm facing this problem now. |
createbaffles, nfaces 0 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 05:20 |
Simulation of Radial Fan with simpleFoam MRF | nash | OpenFOAM Running, Solving & CFD | 2 | November 5, 2015 11:12 |
CyclicAMI BC preservePatches Parallel Run - again!?! | hxaxtma | OpenFOAM Pre-Processing | 4 | August 31, 2015 18:47 |
Floating Point Exception - wrong boundaries or general PC problem? – OF 1.6 extend - | A.Wendy | OpenFOAM | 0 | February 27, 2013 05:50 |
MRFSimpleFoam Tutorial | bastil | OpenFOAM Running, Solving & CFD | 48 | August 1, 2012 11:00 |
