Cedric
Rep Power: 12 ![]() |
Hi everybody,
I 'm trying to perform a simulation of wind on a building in order to know the pressure on a particular part of a building roof. I follow the simplefoam/motorbike tutorial and I adjust it to my case. But when I try to see the result in paraview, it's wrong!(pictures). I think it can be a problem of dimensions in my blockMesh but I tried different solutions and I failed. Could somebody explain me why it doesn't work please ? (I'm a beginner in OF) |
what is your inlet condition? (by the way the others)
Don't forget that you are in ABL condition many things need to be change. And then motorbike simulation don't agree with your simulation what is your domain size compare to the building size? |
Cedric
Thank for your reply. I'm a very beginner and I guessed I just had to "replace" the motorbike by my own geometry. I'm not sure to understand what you mean by Inlet Condition but I attached some files I hope it's what you mean. I'am doing research on ABL as you advised to me but, for the moment, I have not the solution. You said the motorbike tutorial wasn't the good one, could you advise me an other one? About my domain size : If I call L the maximum lenght of my building, il have 3L between my building and the inlet, 3L on each side and 8L behind. Thank for your help. |
My meaning is that you are in atmospheric boundary layer condition. So you need to apply a log-law (or the power law) on the inlet and change the inlet accordingly to the epsilon (or omega) and to the Turbulent Kinetic Energy (TKE can stay in fixed value).
You can have a try with the boundary condition in the turbineSitting tutorial located in the simpleFoam's tutorial part. There you will have the different inlet (k-epsilon) and also you can use the nut bottom boundary to model grass or road around your buildings. regards GJ |
Cedric
Hello GJ,
Unfortunatly, I have no time to work on it until today. I look at the tutorial you advice me and I think I understand what mean ABLC now but I steel don't see how to change my inlet to have a log-law. Indeed, I undersatnd why I must do it but as I am a very beginner in C++, I can't see how to set up it in an OpenFoam file... Thank you very much for your help, Regards Cedric |
Hi there you needn't to program
just look at tutorials/incompressible/simpleFoam/turbineSiting it show the different inlet for ABL layer epsilon : atmBoundaryLayerInletEpsilon k : uniformFixedValue nut : nutkAtmRoughWallFunction U : atmBoundaryLayerInletVelocity these are a little outdated inlet I suggest you to have a look of this article for parametrize your inlet Yang, Y., M. Gu, S. Chen, and X. Jin, 2009: New inflow boundary conditions for modelling the neutral equilibrium atmospheric boundary layer in computational wind engineering. Journal of wind engineering and industrial aerodynamic, 95, 88–95. f And you should lower the constant C_\mu of the bradshaw relationship from 0.09 to 0.03 And change the turbulent kinetic energy inlet accordingly |
#7 | |
Cedric
I'm traying to adjust the turbinesiting tutorial to my case but there still is a file I don't understand everythings. When I look at the Allrun, I undersand until SnappyHexMesh, after I cut off the topoSet "step" as I think it is useless (I also cut off fvOption). But I can't manage to run my case. Here is the error message : Quote:
Cedric
Hi, I worked on it the all day and I finally managed to have results for my own stl.
After that, I searched for renseignement on "U : atmBoundaryLayerInletVelocity" and there are somethings I can't anderstand and I hope you could help me. As you can see in the pictures I attached, the results are diferents when I use Excel with the U atmBoundaryLayerInletVelocity equation and when I watch the same thing with Paraview. Moreover I can't understand why there is no correspondance between the Href/Uref theoric (I put in the ABLConditions file in OpenFoam) and the Href/Uref I visualise paraview. I hope I clear enought. Regards, Cedric |
#9 |
#10 |
Cedric
Hi Elvis,
Thanks for your reply. I look at the 2 examples you adviced me. I guess it can be usefull to compare with my model when it will work but I still can't understand why I get this diffences between the theory (with excel) and the simulation (in OpenFoam) as I assume it the same equation at the base. |
#11 |
Cedric
Hi everybody,
Now, I manage to perform a case with my building thank to your help. I have just an other question concerning the boundaries : why the tutorial "turbinesitting" doesn't use the condition "symmetrtPlane" on the sides and the top boundaries? Thanks for your replies, Regards, Cedric |
#12 |
Cedric
I had no understand what "symettryPlane" condition mean in OpenFoam, I use an other soft where it means that the conditions one the one side of the boundary is the same that on the other side, whereas in OF it means just a "basic" symmetryPlane which make a symetrie. It is usefull if you have a symetry on your domain for exemple but it's no use to define a boundary limit. |
#13 |
if you use symettryPlane you need to link it to one other face. But it's only good for geometrical design (in order to save memory and time). slip condition is a good condition.
you should have a look on the thesis : Wind resource in complex terrain with OpenFoam June 2011 by Benjamin Martinez (it s almost the same as turbine sitting tutorial) It's a very good thesis, everything is well explained from the boundary to the resolution. It helped me a lot.
------------------------------------------------------- Gregoire Junqua Ocean University of China PhD Oceanography/ABL turbulence ------------------------------------------------------- |
#14 |
Cedric
Hi Greg,
Thanks for your reply about my boundary condition. I found the these you advice me toread, it's indeed very interresting for my studies! I'm trying to reproduce a study somebody else has done on an hospital, I manage to reproduce the general comportement but there are détails I still can't reproduce (picture). In your opinion, where does the problem come from? The precision of the snappyHexMesh (I tried to incress it several times but I still can't have the comportement I joined my file) or an other parameter I don't see yet? |
#15 |
fangyingwang
Rep Power: 0 ![]() |
hi!!cedrik! i can't found the these above advised by gregjunqua! could you sent it to me use email ? thanks
building, motorbike tutorial |
Wind turbine simulation problem | sanchovg2 | STAR-CCM+ | 12 | March 5, 2013 04:18 |
shaft power versus RMP curve in wind turbine simulation | zhenduan306 | CFX | 28 | November 8, 2012 10:11 |
3D simulation of wind turbine in Yaw wind(in a lateral wind) | mohammad | Main CFD Forum | 0 | December 28, 2010 03:26 |
something wrong in tutorial of simulation of wind around building... | teguhtf | ANSYS | 0 | December 11, 2010 18:53 |
OF suitable for dynamic building simulation? | pizzaice | OpenFOAM Running, Solving & CFD | 0 | November 27, 2009 08:02 |
