Multi subset mesh motion
Like Tree1Likes
  • 1 Post By hchen
Old   August 15, 2014, 12:13
Default Multi subset mesh motion
Hao Chen
hchen is on a distinguished road
Hello:
I intend to use subset mesh motion in foam-extend 3.1 for multiple subset mesh motion.
The idea is to cut the mesh to two or more different connect parts, the exposed faces acts as the boundary patch and are imposed the boundary conditions. different mesh parts may have different mesh motion solvers.
I am going to modify a little bit on the source code of the subset mesh motion class. It should be fairly easy but unfortunately I am not so good at C++. Should I create two motion solver autoPtr, then in the case file I should have two dynamicMeshDict? how should the program knows which solver acts on which parts?
Best regards
Hao
Zane likes this.
hchen is offline   Reply With Quote
Old   August 18, 2014, 11:25
Hao Chen
Any body has some idea about it?
Old   October 22, 2015, 08:51
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Dear Hao,
Have you succeeded on this issue?
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   March 6, 2022, 00:41
Pengcheng Zhang
Zane is on a distinguished road
It's been so long, does anyone have a clue about this issue?
Zane is offline   Reply With Quote
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 11:04
very fragile mesh motion on SnappyHexMesh generated mesh matteoL OpenFOAM Running, Solving & CFD 0 April 14, 2012 14:51
[Other] 2D hex mesh on multi element airfoil Verfblikje OpenFOAM Meshing & Mesh Conversion 0 January 19, 2012 11:55
Prescribed mesh motion does not correspond to actual motion rbarrett CFX 8 June 30, 2011 14:22
