confused with units in solidThermophysical properties and Thermophysical properties |
August 12, 2014, 17:35 |
zahra
Rep Power: 12 |
I am modeling in chtMultiRegionFoam and i am confused with solidThermophysical properties and Thermophysical properties folders. here are two of folders, at first consider solidThermophysical properties folder : { //- thermo properties rho rho [1 -3 0 0 0 0 0] 2500; Cp Cp [0 2 -2 -1 0 0 0] 750; K K [1 1 -3 -1 0 0 0] 1.4; //- radiation properties kappa kappa [0 -1 0 0 0 0 0] 0; sigmaS sigmaS [0 -1 0 0 0 0 0] 0; emissivity emissivity [0 0 0 0 0 0 0] .88; //- chemical properties Hf Hf [0 2 -2 0 0 0 0] 0; } what are kappa and simaS and Hf? what is the Hf's unit? and here is one of thermophysical properties folder: mixture { specie { nMoles 1; molWeight 28.97; } thermodynamics { Cp 1007.526; Hf 0; } transport { mu 1.908068e-05; Pr 0.705159; } What are the units of Cp , Hf , mu ? Regards |
August 13, 2014, 14:04 |
zahra
Rep Power: 12 |
no body have not faced with thermophysical properties and solidthermophysical properties?!!
August 13, 2014, 16:06 |
Lorenzo Gomes
Rep Power: 13 |
They are all in the International System of units. The user guide helps you a little.
HTML Code:
http://www.openfoam.org/docs/user/basic-file-format.php#x18-1010004.2.7 |
August 14, 2014, 09:11 |
zahra
Rep Power: 12 |
Thank you Lorenzo. in some Froums there was a hot discussion on these units in some cases. so i was not sure. thank you again
Error in thermophysical properties (chtMultiRegionFoam) | mukut | OpenFOAM Pre-Processing | 28 | November 23, 2021 07:34 |
Thermophysical Property Units | johanz | OpenFOAM Pre-Processing | 2 | December 16, 2018 11:08 |
table properties for thermophysical properties | romant | OpenFOAM Running, Solving & CFD | 1 | August 12, 2014 09:41 |
Thermophysical properties for natural convection | Ciefdi | OpenFOAM Running, Solving & CFD | 0 | November 7, 2013 12:44 |
accessing thermophysical properties on a lower level | romant | OpenFOAM Programming & Development | 4 | October 28, 2013 09:25 |
