August 12, 2014, 14:27 |
shallowWaterFoam boundary&initial conditions
Shabir Mohamed
Rep Power: 12 |
I am new to CFD and I am hoping to use OpenFOAM for my research. I am trying to solve for the height fields of waves in shallow waters. I am trying to do it using the shallowWaterFoam solver. Can someone explain to me what the example given for this in OpenFOAM does??? When I run it and check the magnitude of U in paraview, I see there a initial trigger at the inlet and then after the simulation period the entire mesh has a uniform constant velocity.... What is happening? what does initial conditions and boundary conditions mean? Is it an example to show how the height fields change over the running time when a small trigger is placed at the inlet when the simulation starts?? Please help... |
August 17, 2014, 06:40 |
#2 | |
Shabir Mohamed
Rep Power: 12 |
Any replies on this???
August 17, 2014, 15:33 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Furthermore, the shallow water equations can be considered as the lowest order Boussinesq approximation, which means that you will have extremely poor dispersive properties, unless all waves are very long compared to the water depth.
Therefore, shallowWaterFoam does not sound like a suitable tool for the modelling of the propagation of waves in a depth integrated model formulation. There is, however, to my knowledge not any higher order Boussinesq implementation available for OpenFoam at the present state. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
examples, groovybc, new to cfd, shallow water, shallow water equations |
non reflective boundary conditions for incompresible flow | Pascal_doran | OpenFOAM Programming & Development | 16 | August 25, 2015 06:35 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 06:58 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Update boundary conditions calculated by an external program | CedricVH | OpenFOAM | 2 | January 15, 2010 12:55 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 02:54 |
