July 29, 2014, 11:05 |
Foam Error - Turbulence Model?
Gowain
Rep Power: 12 |
Hi
I am trying to do a thermal evaluation on the human body (see attached image for idea of geometry) - I am using buoyantBoussinesqueSimpleFoam solver and receive the following error - I wish to use kepsilon model for the human body - I am relatively new to openFoam and would appreciate some guidance and insight into the following error message: Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Creating turbulence model Selecting RAS turbulence model kEpsilon --> FOAM FATAL IO ERROR: Cannot find patchField entry for body file: /home/gowain/OpenFOAM/OpenFOAM-2.3.0/tutorials/heatTransfer/buoyantBoussinesqSimpleFoam/humanmodel/0/k.boundaryField from line 29 to line 30. From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) in file /home/gowain/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 209. FOAM exiting many thanks g |
July 29, 2014, 11:16 |
I think you defined a "body" patch in constant/polymesh/boundary, but you're missing the same on 0 folder in k file...read carfeully OF always says where you're wrong...at least for the 99% of the cases .
did you obtain the mesh by using Engrid? |
July 29, 2014, 12:34 |
Gowain
Rep Power: 12 |
Hi - thanks for the response
I created the model on blender and meshed the domain and body with engrid (see attached) I thought that was the problem also but it appears not, unless my patch is wrongly defined, here are my k and boundary files: FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 9 ( back { type empty; nFaces 1725; startFace 3014960; } body { type wall; nFaces 84480; startFace 3016685; } bottom { type empty; nFaces 1719; startFace 3101165; } front { type empty; nFaces 1771; startFace 3102884; } inlet { type patch; nFaces 96; startFace 3104655; } left { type empty; nFaces 1595; startFace 3104751; } outlet { type patch; nFaces 100; startFace 3106346; } right { type empty; nFaces 1831; startFace 3106446; } top { type empty; nFaces 1659; startFace 3108277; } ) and FoamFile { version 2.0; format binary; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.1; boundaryField { boundaryField { body { type kqRwallFunction; value uniform 0.1; } } many thanks |
July 29, 2014, 13:24 |
#4 | |
I don't see anything wrong, apart from this
The only suggestion I have is to copy one working file from another case. Furthermore, are you sure you have to define into polyMesh/boundary: top, bottom, left, right, front, back as empty? If I rembember well, empty is used to reduce the dimension of the problem (cavity case), why don't you use periodic, cyclic or other boundary type? |
July 30, 2014, 09:30 |
Gowain
Rep Power: 12 |
Thanks for the response - I managed to get the error sorted but alas I have encountered another error on the nut file that has me somewhat perplexed - I would be grateful if you could shed some light on it if possible:
--> FOAM FATAL ERROR: Attempt to return primitive entry ITstream : /home/gowain/OpenFOAM/OpenFOAM-2.3.0/tutorials/heatTransfer/buoyantBoussinesqSimpleFoam/humanmodel/0/nut.boundaryField.outlet, line 60, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD primitiveEntry 'outlet' comprises on line 60 the word 'type' on line 60 the word 'calculated' as a sub-dictionary From function const dictionary& primitiveEntry::dict() const in file db/dictionary/primitiveEntry/primitiveEntry.C at line 191. FOAM aborting thanks so much apologies again g |
July 30, 2014, 13:34 |
how did you managed the problem before?
About new one, I think there's a mismatching between calculated and boundary type. I face problem like this one when I made following error: on boundary I defined the type patch eg: inlet = patch, while in the 0 folder I set inlet = empty; basic type are in contrast. I suggest to check this way...let me know... |
July 31, 2014, 17:47 |
Gowain
Rep Power: 12 |
HI -
I managed to fix the above two errors - it was simple mistake; however I now get a running error when I run the solver buoyantBoussinesqSimpleFoam - I am still relatively new to OF and I am sure the error lies in case files - maybe. Or it is due to my limited computer resources - I intend to run the simulation from starttime 0 to endtime 100 whereby delta t is 0.25 at a write interval of 4 - I am sure this corresponds to a courant number <1 I receive the following error at 6 seconds into the sim - always at 6 seconds: Time = 6 DILUPBiCG: Solving for T, Initial residual = 0.900926, Final residual = 0.011827, No Iterations 1 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam:ICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) at ??:? #4 Foam:ICPreconditioner:ICPreconditioner(Foam::l duMatrix::solver const&, Foam::dictionary const&) at ??:? #5 Foam::lduMatrix:reconditioner::addsymMatrixConst ructorToTable<Foam:ICPreconditioner>::New(Foam:: lduMatrix::solver const&, Foam::dictionary const&) at ??:? #6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) at ??:? #7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #8 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #10 at ??:? #11 at ??:? #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 at ??:? Floating point exception (core dumped) - Any pointers into what is wrong? kind regards g |
December 14, 2016, 13:52 |
Error in OpenFOAM
Pedro
Rep Power: 10 |
Dear Foamers,
I have been trying to do a simulation using pisoFoam solver. However, I face the following error while doing the simulation. Any help is greatly appreciated. Pedram Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kOmega --> FOAM FATAL ERROR: Attempt to return primitive entry ITstream : /scratch/user//constant/RASProperties.kOmegaCoeffs, line 24, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD primitiveEntry 'kOmegaCoeffs' comprises on line 24 the word 'printCoeffs' on line 24 the word 'on' as a sub-dictionary From function const dictionary& primitiveEntry::dict() const in file db/dictionary/primitiveEntry/primitiveEntry.C at line 191. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" #2 Foam:rimitiveEntry::dict() const in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" #3 Foam::dictionary::subOrEmptyDict(Foam::word const&, bool) const in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/lib/libOpenFOAM.so" #4 Foam::incompressible::RASModel::RASModel(Foam::wor d const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/lib/libincompressibleRASModels.so" #5 Foam::incompressible::RASModels::kOmega::kOmega(Fo am::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&, Foam::word const&) in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/lib/libincompressibleRASModels.so" #6 Foam::incompressible::RASModel::adddictionaryConst ructorToTable<Foam::incompressible::RASModels::kOm ega>::New(Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/lib/libincompressibleRASModels.so" #7 Foam::incompressible::RASModel::New(Foam::Geometri cField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/lib/libincompressibleRASModels.so" #8 Foam::incompressible::turbulenceModel::addturbulen ceModelConstructorToTable<Foam::incompressible::RA SModel>::NewturbulenceModel(Foam::GeometricField<F oam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/lib/libincompressibleRASModels.so" #9 Foam::incompressible::turbulenceModel::New(Foam::G eometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/lib/libincompressibleTurbulenceModel.so" #10 in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/bin/pisoFoam" #11 __libc_start_main in "/lib64/libc.so.6" #12 in "/software/easybuild/software/OpenFOAM/2.3.1-intel-2015B/OpenFOAM-2.3.1/platforms/linux64IccDPOpt/bin/pisoFoam" Aborted (core dumped) |
January 3, 2018, 12:47 |
#9 |
Guillaume
Rep Power: 9 |
Hi all,
It would be good to share with us how you solved the problems you had... Can you tell us how you solved them? I am getting the following error: --> FOAM FATAL ERROR: Attempt to return primitive entry ITstream : /home/guillaume/OpenFOAM/Whirljet/WhirlJet7/0/epsilon.boundaryField.bc_outlet, line 37, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD primitiveEntry 'bc_outlet' comprises on line 37 the word 'type' on line 37 the word 'zeroGradient' as a sub-dictionary From function virtual const Foam::dictionary& Foam:rimitiveEntry::dict() const in file db/dictionary/primitiveEntry/primitiveEntry.C at line 189. FOAM aborting Thank you for your help, Guillaume |
May 22, 2020, 07:55 |
#10 |
Prof Dr A P Schaffarczyk
Guillaume,
did you resolve your error ? I've got the same in connection with snappyHexMesh Best wishes Peter |
[OpenFOAM] Take derivative of mean velocity in paraFoam | hiuluom | ParaView | 13 | April 26, 2016 07:44 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
