Defining a new constant vector source in wall interaction models for Lagrangian cases
Like Tree1Likes
  • 1 Post By ansubru
Old   July 29, 2014, 06:03
Default Defining a new constant vector source in wall interaction models for Lagrangian cases
Ananda Kannan
ansubru is on a distinguished road
Good day Foamers!!
I have a rather trivial error. I wanted to add a pre-defined velocity vector source within the 'wall model' in
lagrangian/intermediate/submodels/Kinematic/CollisionModel/PairCollision/WallModel/WallSpringSliderDashpot
I need to introduce an extra source term to the total wall force p.f(). This term will be adding some new interactions (apart from collision and cohesion) to the wall interaction model. I have added the following lines of code to the 'original' script WallSpringSliderDashpot.C -
// Hard-coding vibrational wall
   scalar rho_wall = 8000; // Steel density in kg/m3
   scalar m_wall = (rho_wall*(3.14/6.0))*(p.d()*p.d()*p.d());
   scalar Ux = 0;
   scalar Uy = 1;
   scalar Uz = 0;
   v_w = vector(Ux, Uy, Uz); // Wall vib source direction and magnitude
   vector f_vib = (p.mass()*p.U()) - (m_wall*v_w);
   p.f() += f_vib; // adding the new vib source
My definition of 'v_w' is not being accepted by the compiler, and I get the following error -
In file included from lnInclude/WallSpringSliderDashpot.H:179:0,
                 from lnInclude/makeParcelCollisionModels.H:36,
                 from parcels/derived/basicKinematicCollidingParcel/makeBasicKinematicCollidingParcelSubmodels.C:34:
lnInclude/WallSpringSliderDashpot.C: In member function ‘void Foam::WallSpringSliderDashpot<CloudType>::evaluateWall(typename CloudType::parcelType&, const point&, const Foam::WallSiteData<Foam::Vector<double> >&, Foam::scalar, Foam::scalar, bool) const’:
lnInclude/WallSpringSliderDashpot.C:163:4: error: ‘v_w’ was not declared in this scope
make: *** [Make/linux64GccDPDebug/makeBasicKinematicCollidingParcelSubmodels.o] Error 1
Is there an alternate way to define 'v_w' so that it falls within the scope of the compiler??
Thanks in advance
BR
ansubru
ansubru is offline   Reply With Quote
Old   July 29, 2014, 06:23
Ananda Kannan
Hi Again!!
That was a rather lame error -
I figured out the solution,
using -
vector v_w = vector(Ux, Uy, Uz);
My issue is solved.. ..
ansubru
arch.mr likes this.
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
Wall functions? Pr Main CFD Forum 7 April 8, 2004 07:15
Constant wall heat flux with uniform temperature Jake FLUENT 2 September 29, 2003 12:34
X-Y plot of Yplus in Fluent 5.3 Luo FLUENT 24 April 11, 2000 07:07
