Piecewise function for properties
Like Tree1Likes
  • 1 Post By SamZar
Old   July 16, 2014, 12:08
Question Piecewise function for properties
P1361 is on a distinguished road
Hi everybody,
I want to use buoyantPimpleFoam solver in OF 2.22 for buoyancy driven flow of a fluid with temperature-dependent thermal/transport properties.
I have two questions now:
- for the equation of state, is it okay to use icoPolynomial? I believe, since the solver is pressure-based and my variations of density with pressure are negligible for my case, it should work. Any objection?
- my property functions (almost all of them) are kind of complex, so that a single polynomial (even of order 8-9) does not really yield satisfactory approximations. I want to use piecewise polynomial (or possibly another function) instead. Any suggestion of where to start?
Thank you very much in advance.
P
P1361 is offline   Reply With Quote
Old   May 14, 2019, 12:30
SamZar is on a distinguished road
I have noticed that this is an old thread. But I have the same issue: how can I define a piecewise function for propeties as a function of temperature in OpenFOAM?
Hope I can find my answer. Thanks.
fuad likes this.
SamZar is offline   Reply With Quote
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
