July 15, 2014, 04:29 |
subcritical OUTLET at free surface channel
mattia
Rep Power: 12 |
Hello, when you have a water outlet with subcritical flow (the upstream level is determined of downstream level), what values you put in U, P_rgh, turbulence and phase fraction?
And when flow is supercritical what values you put? Thanks, Mattia |
July 15, 2014, 04:40 |
Albrecht vBoetticher
Rep Power: 17 |
Hi, do you know the level of the surface at the downstream, behind your outlet? Or do you want it yust to be equal to whatever surface level you get close to the outlet in your simulation? There are several posibilities, thats why I ask.
July 15, 2014, 04:59 |
mattia
Rep Power: 12 |
Hi, I know the level of the surface at the downstream.
Thank you. |
outflow boundary, subcritical, supercritical water |
how to capture free surface cells? | MichaelVS | FLUENT | 1 | June 10, 2015 02:18 |
determine surface height without input (open channel ; free surface and bottom) given | stefenbink | FLUENT | 13 | January 2, 2014 13:38 |
UDF Defining VOF Free Surface at Outlet | Alex | Fluent UDF and Scheme Programming | 13 | August 8, 2012 16:50 |
BC for free surface in straightopen channel flow | moon1234 | FLUENT | 0 | March 15, 2010 06:50 |
pressure outlet (open channel flow) | Willem Brantegem | FLUENT | 2 | April 4, 2007 02:40 |
