Longfei
Rep Power: 0 ![]() |
Hi all,
I am trying to read a csv file into the velocity boundary conditions (FOAM_CASE/0/U), and below is what I did. Code:
mainJet { type timeVaryingMappedFixedValue; offset csvFile; csvFileCoeffs { nHeaderLine 0; refColumn 0; componentColumns (1 2 3); separator ","; mergeSeparators no; fileName "myDataFile"; outOfBounds clamp; interpolationScheme linear; }; setAverage off; } Can some one tell me what is the problem with my csv file and csvFileCoeffs settings? Everytime when I try to run the case I get the following error message from OpenFOAM: Code:
--> FOAM FATAL IO ERROR: Cannot open CSV file for reading. file: myDataFile at line 1. From function CSV<Type>::read() in file lnInclude/CSV.C at line 82. FOAM exiting Thanks in advance! Longfei |
Manjunath Reddy
Rep Power: 13 ![]() |
You should give the path of the file where you didn't mention it. it should be like this fileName "$FOAM_CASE/mydataFile"; and you should place your file in the case folder. |
csv |
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam | jlpelerin | OpenFOAM Meshing & Mesh Conversion | 4 | April 25, 2011 16:56 |
Reading .srp/.vrp files into Matlab | Will Humber | FLUENT | 0 | February 13, 2008 13:20 |
Grid reading problem on parallel machine | wies | FLUENT | 0 | September 15, 2005 10:18 |
Error Reading files | Mark | FLUENT | 0 | August 26, 2005 16:04 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
