Error while compiling modified icoFoam: "cannot find lthermophysicalModels" |
June 15, 2014, 07:36 |
Duarte Magalhães
Rep Power: 12 |
Hi everyone!
I am using OpenFOAM 2.3.0 and trying to compile a modified version of icoFoam (with temperature equation and thermophysical properties varying with temperature) and I'm getting the following error: " /usr/bin/ld: cannot find -lthermophysicalModels collect2: ld returned 1 exit status make: *** [/home/duarte/OpenFOAM/duarte-2.3.0/platforms/linuxGccDPOpt/bin/own_icoFoamPV] Error 1 " Can anyone tell me how can I make the program find this library? Thank you for your help! (I'm afraid this post is in the wrong sub-forum as I haven't seen many threads about compilation errors around here. If so, please redirect me to the correct one) |
June 15, 2014, 08:48 |
if you take a look at options files in Make folder of compressible solvers, usually it is: Code:
... EXE_LIBS = \ -lfluidThermophysicalModels \ -lspecie \ ... |
June 15, 2014, 09:47 |
Duarte Magalhães
Rep Power: 12 |
Hi Alexey,
Thank you for your quick reply! My Make/options file is as follows: " EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/sampling/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/basic/rhoThermo \ -I$(LIB_SRC)/thermophysicalModels/basic/fluidThermo \ -I$(LIB_SRC)/thermophysicalModels/basic/basicThermo EXE_LIBS = \ -lfiniteVolume \ -lsampling \ -lthermophysicalModels " I thought this was correct. I am using rhoThermo to calculate the fields rho () and mu (). I just need these fields from rhoThermo. Please advise, thanks a lot! |
June 15, 2014, 09:56 |
Well,
$ cd $FOAM_LIBBIN $ pwd .../OpenFOAM-2.3.0/platforms/.../lib $ ls | grep Thermo libSLGThermo.dylib libfluidThermophysicalModels.dylib libmultiphaseMixtureThermo.dylib libreactionThermophysicalModels.dylib libsolidThermo.dylib libtwoPhaseMixtureThermo.dylib $ |
June 15, 2014, 13:27 |
Duarte Magalhães
Rep Power: 12 |
Alexey,
You are right. There is a libfluidThermophysicalModels.so file in the opt/openfoam230/platforms/LinuxGccDPOpt/lib directory, and not a libthermophysicalModels.so file. However, in opt/openfoam230/src, I cannot find a "fluidThermophysical" directory, but there is a thermophysicalModels directory Supposedly, existing a thermophysicalModels directory in /src, a .so file would be expected to exist in opt/openfoam230/platforms/LinuxGccDPOpt/lib directory, right? |
June 15, 2014, 13:44 |
Duarte Magalhães
Rep Power: 12 |
Ok, problem solved, I was getting it all wrong, my options file ended up as:
EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/sampling/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude EXE_LIBS = \ -lfiniteVolume \ -lsampling \ -lfluidThermophysicalModels \ -lspecie Thank you so much for your help Alexey! |
June 15, 2014, 15:03 |
Not exactly. It's right, for example, for surfMesh folder in src (so it's libsurfMesh.so), turbulenceModels folder (it's turbulenceModels.so), but thermophysicalModels are split into several dynamic libraries (thermophysicalModels/basic -> libfluidThermophysicalModels.so, thermophysicalModels/SLGThermo -> libSLGThermo.so, etc.). Another example of such split is postProcessing folder.
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 01:52 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 13:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 07:32 |
Error "cannot find -lz" | athlonshi | OpenFOAM Installation | 2 | September 19, 2010 16:59 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
