June 11, 2014, 10:50 |
filling a tank with water
ashwin
Rep Power: 14 |
I am trying to fill a tank with water as shown in the figure. The red line indicates the water inlet at t=0 and the green line indicates the air exit. The picture was taken at 46 secs with the timestep being 0.0001. I have been running the case for over two weeks and the water level stopped to be filled in as in the screenshot. I am using the following initial conditions. alpha.water Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type inletOutlet; inletValue uniform 1; value uniform 1; } outlet { type zeroGradient; } walls { type zeroGradient; } } Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type fixedFluxPressure; value uniform 0; } outlet { type outletInlet; outletValue uniform 0; value uniform 0; } walls { type totalPressure; p0 uniform 0; U U; phi phi; rho rho; psi none; gamma 1; value uniform 0; } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (2 0 0); } outlet { type pressureInletOutletVelocity; value uniform (0 0 0); } walls { type fixedValue; value uniform (0 0 0); } } Regards Ashwin |
June 11, 2014, 19:11 |
Wouter van der Meer
Rep Power: 18 |
hello ashghan,
The problem is the pressure definition. The number of variables is not equal to the number of freedom. Your system needs a point where the pressure is known. If you look at the angledDuct turorial and remove the viscosity things (in 0 dir two boundaries, in fvOptions remove all you have a working case. I did this with a simple form of your fueltank? It ran for less than 4 hours. I enclosed my case, but I had to remove the mesh because of the size restrictions. Hope this helps Wouter Last edited by wouter; June 15, 2014 at 19:00. |
June 18, 2014, 09:28 |
#3 | |
ashwin
Rep Power: 14 |
Hey,
Yeah it works. Thanks Quote:
August 21, 2017, 08:15 |
Help
Rep Power: 13 |
I am trying to solve water filling bottle tutorial from long back (http://www.tfd.chalmers.se/~hani/kur...Hemida_VOF.pdf). I am not getting reasonable results. I used inlet velocity as 0.1 m/sec. I am attaching my FOAM files. Please kindly let me know what mistake I am doing. |
Filling Tank with Water | leff | CFX | 7 | August 21, 2017 08:47 |
Filling tank with water | Bin | ANSYS | 1 | August 21, 2017 08:17 |
Simple Water Tank Transient | 88phil88 | CFX | 5 | March 17, 2014 04:48 |
Mixture and Decay of a tracer in a Water Tank | Jeffrey1992 | CFX | 2 | July 27, 2012 14:31 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 08:10 |
