June 11, 2014, 08:05 |
Problem running in parralel
Valentin
Rep Power: 12 |
Hi all, I'm new with OpenFoam (few days), and i'am trying to run in parallel.
I have a decomposeParDict file which works. But when i try to run typing this : mpirun -np 4 icoFoam -parallel i get the following errors : Code:
It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): orte_ess_base_build_nidmap failed --> Returned value Data unpack would read past end of buffer (-26) instead of ORTE_SUCCESS -------------------------------------------------------------------------- -------------------------------------------------------------------------- It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): orte_ess_set_name failed --> Returned value Data unpack would read past end of buffer (-26) instead of ORTE_SUCCESS -------------------------------------------------------------------------- [bxp0205linux:10408] [[55415,1],0] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/util/nidmap.c at line 398 [bxp0205linux:10408] [[55415,1],0] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../orte/mca/ess/base/ess_base_nidmap.c at line 62 [bxp0205linux:10408] [[55415,1],0] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../../orte/mca/ess/env/ess_env_module.c at line 173 [bxp0205linux:10408] [[55415,1],0] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/runtime/orte_init.c at line 132 *** The MPI_Init() function was called before MPI_INIT was invoked. *** This is disallowed by the MPI standard. *** Your MPI job will now abort. [bxp0205linux:10408] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: orte_init failed --> Returned "Data unpack would read past end of buffer" (-26) instead of "Success" (0) -------------------------------------------------------------------------- [bxp0205linux:10409] [[55415,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/util/nidmap.c at line 398 [bxp0205linux:10409] [[55415,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../orte/mca/ess/base/ess_base_nidmap.c at line 62 [bxp0205linux:10409] [[55415,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../../orte/mca/ess/env/ess_env_module.c at line 173 [bxp0205linux:10409] [[55415,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/runtime/orte_init.c at line 132 -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: orte_init failed --> Returned "Data unpack would read past end of buffer" (-26) instead of "Success" (0) -------------------------------------------------------------------------- *** The MPI_Init() function was called before MPI_INIT was invoked. *** This is disallowed by the MPI standard. *** Your MPI job will now abort. [bxp0205linux:10409] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! [bxp0205linux:10410] [[55415,1],2] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/util/nidmap.c at line 398 [bxp0205linux:10410] [[55415,1],2] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../orte/mca/ess/base/ess_base_nidmap.c at line 62 [bxp0205linux:10410] [[55415,1],2] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../../orte/mca/ess/env/ess_env_module.c at line 173 [bxp0205linux:10410] [[55415,1],2] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/runtime/orte_init.c at line 132 *** The MPI_Init() function was called before MPI_INIT was invoked. *** This is disallowed by the MPI standard. *** Your MPI job will now abort. [bxp0205linux:10410] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: orte_init failed --> Returned "Data unpack would read past end of buffer" (-26) instead of "Success" (0) -------------------------------------------------------------------------- [bxp0205linux:10411] [[55415,1],3] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/util/nidmap.c at line 398 [bxp0205linux:10411] [[55415,1],3] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../orte/mca/ess/base/ess_base_nidmap.c at line 62 [bxp0205linux:10411] [[55415,1],3] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../../orte/mca/ess/env/ess_env_module.c at line 173 [bxp0205linux:10411] [[55415,1],3] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/runtime/orte_init.c at line 132 -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: orte_init failed --> Returned "Data unpack would read past end of buffer" (-26) instead of "Success" (0) -------------------------------------------------------------------------- *** The MPI_Init() function was called before MPI_INIT was invoked. *** This is disallowed by the MPI standard. *** Your MPI job will now abort. [bxp0205linux:10411] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 10408 on node bxp0205linux exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [bxp0205linux:10407] 3 more processes have sent help message help-orte-runtime.txt / orte_init:startup:internal-failure [bxp0205linux:10407] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages [bxp0205linux:10407] 3 more processes have sent help message help-orte-runtime / orte_init:startup:internal-failure |
June 12, 2014, 02:47 |
Valentin
Rep Power: 12 |
I finally re-install Openfoam with the source pack :
http://www.openfoam.org/download/source.php instead of the ubuntu deb pack... and it works !! |
Parallel running of 3D multiphase turbulence model (unknown problem!!) | MOHAMMAD67 | OpenFOAM Running, Solving & CFD | 7 | November 23, 2015 10:53 |
running FLUENT on cluster problem | cth_yao | FLUENT | 2 | December 2, 2011 06:05 |
problem with running in parallel | dhruv | OpenFOAM | 3 | November 25, 2011 05:06 |
Problem running parallel. | Hernán | STAR-CCM+ | 1 | December 23, 2009 12:04 |
Problem running parallel | Hernán | Main CFD Forum | 0 | December 22, 2009 04:36 |
