interFoam alphaEqn: TVD+MULES - why both?
Like Tree1Likes
  • 1 Post By santiagomarquezd
Old   June 6, 2014, 09:32
Question interFoam alphaEqn: TVD+MULES - why both?
Lydia Schulze
Lydia is on a distinguished road
Hello Foamers,
I have a question concerning the alphaEqn of interFoam solver (version 2.2.1):
Why does interFoam first use TVD schemes for the fluxes, which guarantees a boundedness, and then additionally use the MULES limiting, which is made for ensuring a bounded solution?
Looking at Jasak's and Damian's thesis, I read that TVD limits the face value whereas MULES (=FCT) limits the face flux. The methods work differently, however, at the end both are having the same objective: a bounded solution.
... I don't exactly understand why we need both? In which case would there be an unbounded flux that needs to be clipped with the MULES limiter?
Or is MULES only needed, when non-TVD schemes are used?
Can anyone maybe help me understanding this?
Any hints are much appreciated!
Regards,
Lydia
Lydia is offline   Reply With Quote
Old   August 9, 2014, 23:52
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi Lydia, MULES is Flux Corrected Transport. This method blends a Hi-Resolution flux with a Low-Resolution one in order not to exceed local and global maximum. The low resolution (and ever bounded) flux is given by the Upwind scheme, otherwise the Hi-Res flux is given by any scheme you want (central-difference or TVD). Then, the lambda factors for blending are calculated in order to give a bounded solution.
With FCT (MULES) you have better chances to have a bounded solution, specially in multidimensions (I don't exactly why, but it's clear in practice).
Regards.
duan likes this.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
boundedness, fct, interfoam, mules, tvd
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
InterFoam channel Flow runnig very slowly Wokl OpenFOAM Running, Solving & CFD 4 January 9, 2014 03:52
mpirun interFoam very stable --> then blows up ghadab OpenFOAM Running, Solving & CFD 3 October 27, 2013 11:34
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
TVD student Main CFD Forum 6 September 9, 2002 10:19
