Inconsistency in wallHeatFlux utility
Like Tree1Likes
  • 1 Post By Jean El-Hajal
Old   May 21, 2014, 15:53
Default Inconsistency in wallHeatFlux utility
Alex
zfaraday will become famous soon enough
Hello FOAMers!
I am studying a simple case with chtMultiRegionSimpleFoam (just to practice the set up for radiation and heat generation) consisting of 2 cubic solid regions (one is generating heat power, actually its temperature is defined as a constant of 600K because I still don't know how to set up a volumetric heat source) surrounded by a bigger cubic region of air. All of the boundary faces for the air region are isolated (using externalWallHeatFluxTemperature wit q=0) except one (defined as externalWallHeatFluxTemperature with Ta=293K and h=1).
The purpose of this simple case is, of course, study what happens when the heating region heats the whole system, either considering radiation or not.
Then, here comes the point! I executed the wallHeatFlux utility to check the energy balance in the system and I found something that is making me crazy. Below you can see the results I got.
air
Wall heat fluxes [W]
maxY -63.0738
minX -0.003706714
maxX -0.009187714
minY -0.0116676
bottom -0.002245114
top -0.002884371
air_to_heater 141.7464
air_to_object -73.04159
heater
bottom 0
heater_to_air -141.74
object
object_to_air 24.3712
As you can see the heat absorbed by the object (yes, I know, it's the most original name for a region anyone has ever heard) is not the same that goes from the air to the object. Furthermore, right now I realised that the energy in the air is also unbalanced since there is a difference of 5W between then energy coming in and going out of the air domain.
Have anyone experinced something similar any time? Am I doing anything wrong? Is there something going wrong with the utility? Any hint or advice will be more than welcome!
Thanks in advance!
Alex
PS: The results are extracted fom a case without radiation, but the same occurs adding the radiation component.
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   May 21, 2014, 16:39
Jean El-Hajal
Jean El-Hajal is on a distinguished road
Dear Alex,
I did not check you post in details, but today we made a simulation with chtMultiRegionSimpleFoam solver and the externalWallHeatFluxTemperature boundary condition with Ta and h. It did not work for us. Nothing happened it was just like an adiabatic wall.
Hope it help.
Best Regards,
Jean
heba_alaaeldin likes this.
Jean El-Hajal is offline   Reply With Quote
Old   May 21, 2014, 16:48
Alex
Originally Posted by Jean El-Hajal View Post
Dear Alex,
Hope it help.
Best Regards,
Jean
I don't understand what you mean when you say "Nothing happened". Did you get an error? An adiabatic wall doesn't make sense at all. Look at my results, my wall that isn't isolated is the one called "maxY" and, as you can see, is not adiabatic (maxY -63.0738).
Check the values you gave to Ta and h. If Ta is close to the wall temperature then the heat flux will be close to 0. Likewise if you gave h a value close to 0.
Regards,
Alex
Old   May 22, 2014, 05:56
Olivier
olivierG is on a distinguished road
hello,
Which OF version do you use ?
Because there where some bug in 2.2 and 2.3 corrected in 2.3.x.
See http://www.openfoam.org/mantisbt/view.php?id=1258
and http://www.openfoam.org/mantisbt/view.php?id=1108
regards,
olivier
olivierG is offline   Reply With Quote
Old   May 22, 2014, 05:59
Alex
I using 2.2.1 version. Does it mean that I need to install 2.3.x in order to be capable to get the correct results?
Thanks olivierG
Old   May 22, 2014, 06:02
Olivier
the 2.2.x and 2.3.x should work.
regards,
olivier
Old   May 22, 2014, 06:40
Alex
Thank you so much olivier for your information. I will try to install ot when I have time for that.
By the way, in the bugs reported im your links above it is said that this occurs with the externalWallHeatFlux BC. However my main problem occurs in the interface between a solid region and a fluid region and the BC in there is turbulent::TemperatureCoupledBaffleMixed (written from memory, maybe the spelling is not correct). Would your approach solve that issue aswell?
Many thanks!
Old   May 22, 2014, 06:55
Olivier
I don't know for turbulentTemperatureCoupledBaffleMixed, but there where improvement in 2.3 about that (see http://www.openfoam.org/version2.3.0/thermal.php ).
regards,
olivier
Old   May 22, 2014, 09:08
Laurent Fitschy
GDTech is on a distinguished road
Hi Alex,
From my experience, chtMultiRegionSimpleFoam takes sometimes a really large number of iterations to reach thermal convergence (correct energy balance). I suggest you to set probes on walls between fluid and solid regions to monitor temperature. Add this to your controlDict :
functions
    probes
        type            probes;
        functionObjectLibs ("libsampling.so");
        outputControl   timeStep;
        outputInterval  1;
        probeLocations
            ( 0 9.95 19.77 )
            ( 0 -9.95 19.77 )
        fields
            T
Energy balance will be correct when interface temperature do not change anymore.
If this temperature is converged and energy balance is still wrong, your BCs are probably not correct.
Laurent.
GDTech is offline   Reply With Quote
Old   May 22, 2014, 12:57
Alex
Thanks for your advices Olivier and Laurent!
@Laurent, I would like to be able to understand the piece of code you posted because it's the first time I add something like that to the controlDict file and I am getting errors all the time when I try to run the case.
Could you please explain briefly the use and meaning of every field within probes, mainly the probeLocation one. Otherwise, if you can, give me some link or site where I can reveiw some useful documentation.
Thanks again!
Alex
Old   May 23, 2014, 04:06
Laurent Fitschy
Here is some general information about functionObjects :
http://foam.sourceforge.net/docs/cpp/a00002.html
ProbeLocation is a set of points (x, y, z coordinates) where you want to measure the field written in the "fields" token ("T" in my example).
2 points are set in my example, but you can add more if you want.
Laurent.
Old   May 23, 2014, 04:14
Alex
Thank you so much Laurent, that was exactly what I needed!! I will take a look into it later
Old   May 27, 2014, 18:43
Alex
After some days away from OpenFOAM, finally today I got back on track. I could run the case using probes function object, but I didn't see anything. Is it supposed to create some files with the requested results, isn't it? Although I couldn't get anything from function objects functionality, I tried something more visual, that is, I displayed the patches between both surfaces and I found out that the temeprature distribution is the same in both patches. So, where can be the error in my case? What can be wrong in my setup? Or is it something related to the issue mentioned above in the wallHeatFlux utility?
Thanks in advance, any hint will be welcome!
Regards,
Alex
Old   May 28, 2014, 16:32
Alex
Dear Laurent,
sorry for my previous response, I wrote too quick. After looking a little further into the case folder I found the info inside the PostProcessing folder and, indeed, you were right, the temperature seems not to be equal in the same point.
These are the results in the latest time of my simulation for the air region
417.9127       423.2814        -1e+300       428.8006
and here are the results for the object region
350.2071       350.2188       350.1326        -1e+300
The two first values are the important ones. They come from the same points (two different points belonging both to the boundary) in the boundary between both regions. As it is shown, they are not even similar. Thus, finally I could verify that the problem was the thermal convergence in the walls, so what do I need to do to solve that?
On the other hand, as I said in my previous post, I tried to check the temperature values in the walls by using ParaView, this is, I displayed the temperature distribution in the boundary faces (air_to_object and object_to_air) but both distributions were equal! Did I do anything wrong? Is this method not able to identify this issue with thermal convergence?
Many thanks in advance!
Alex
Old   May 30, 2014, 03:55
Laurent Fitschy
Hi Alex,
Well ! So, you need to restart your simulation for a few more iterations until your probes report the same temperature on both sides. It is sometimes really slow to reach thermal convergence, then I also suggest you to follow this tip :
http://www.cfd-online.com/Forums/ope...tml#post338430
I don't know exactly what's happening but my guess is that paraview reads the boundary condition in T file which is the same in both regions ... boundary conditions are equal but not field values just next to the boundary since convergence is not reached ...
Laurent.
Old   May 30, 2014, 08:55
Alex
Originally Posted by GDTech View Post
Hi Alex,
I actually tried it right after posting the comment (again I posted it too fast :P) and, indeed, it was a matter of time, after a few minutes I reached thermal convergence and everything was fine. But then I tried the same case but adding radiation to the case and something weird occurred (at least to my eyes...). It seems to reach steady state, since temperature shown with probes function object remains constant for the last iterations, but the temperature is not the same in both boundaries. When I get home I will upload the results of my case to se if I can get some help.
Laurent.
I don't get what you mean, Laurent. You say that BC are equal in both regions. However, as you can see in the results shown above extrated from probes, in the same point (belonging to the BC of both regions) the temperature is diferent for each region.
Thanks for your explanations, Laurent
Alex
chtmultiregionsimplefoam, radiation, wallheatflux
wallHeatFlux utility for an incompressible case Mr.Jingles OpenFOAM Post-Processing 67 April 6, 2023 04:25
Heat flux calculating with wallHeatFlux utility and alphaEff tanshihaj OpenFOAM Post-Processing 0 March 12, 2014 06:55
wallHeatFlux utility with chtMultiRegionFoam solver. Usem OpenFOAM Programming & Development 9 January 6, 2014 06:10
wallHeatFlux utility and chtMultiRegionFoam solver Lada OpenFOAM Post-Processing 4 June 7, 2012 10:46
wallHeatFlux utility in OpenFoam1.6 maruthamuthu_venkatraman OpenFOAM 29 October 3, 2011 11:43
