turbulentHeatFluxTemperature heat capacity of what material?
Like Tree1Likes
  • 1 Post By jherb
Old   May 7, 2014, 14:22
Default turbulentHeatFluxTemperature heat capacity of what material?
Andrew Somorjai
massive_turbulence is on a distinguished road
Hello everyone,
Looking at the source for the turbulentHeatFluxTemperatureFvPatchScalarField class at
https://github.com/OpenFOAM/OpenFOAM...hScalarField.H
The heat capacity at constant pressure is listed
hotWall
            type            turbulentHeatFluxTemperature;
            heatSource      flux;        // power [W]; flux [W/m2]
            q               uniform 10;  // heat power or flux
            alphaEff        alphaEff;    // alphaEff field name;
                                         // alphaEff in [kg/m/s]
            Cp              Cp;          // Cp field name; Cp in [J/kg/K]
            value           uniform 300; // initial temperature value
If I had a box full of air with a wall made of steel transferring heat would I use the heat capacity of air or steel. I don't suppose the steel part would even matter for the simulation but I'm just not sure if it's simply the air Cp that would be needed. If it's for steel then how come there's no length requirement for the conductor (from the formula for thermal conductivity)?
thanks to anyone for clearing it up.
massive_turbulence is offline   Reply With Quote
Old   May 20, 2014, 12:19
Joachim Herb
jherb is on a distinguished road
With the turbulentHeatFluxTemperatureFvPatchScalarField boundary conditions you transfere a certain amount of heat (either defined as flux, a.k. power/area or total power for the whole surface) into the fluid. Heat conduction in the boundary is not considered, so the heat capacity is the one of the fluid. If you want to simulation also the solid and the heat conduction inside it, you have to go with the multi region solver (see the corresponding tutorias, e.g. heatTransfer/chtMultiRegionFoam etc.)
massive_turbulence likes this.
jherb is offline   Reply With Quote
Old   May 20, 2014, 17:16
Andrew Somorjai
Thank you, that's exactly what I was thinking too but I didn't know about the multi region solver.
Old   May 20, 2014, 18:47
Joachim Herb
Also have a look at this boundary condition:
This might also apply in your case.
heat capacity, thermal coductivity
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Material property Heat transfer mat_cfd CFX 1 February 19, 2013 17:58
heat transfer in an orthotropic material and complex curved geometry zayzan FLUENT 0 October 11, 2011 11:47
