April 29, 2014, 05:47 |
Humid Air Modelisation with OpenFOAM
Rep Power: 12 |
Hi everybody,
I would like to calculate humid air as a perfect mixture of two miscibles components ( air and water vapor) with OpenFOAM and I would like to calculate the relative humidity of this air and the water vapor pressure. I have already use a equivalent fluid from which I have calculated volume-weighted properties. But this time, I would like to have two different parts.I would like to know the way to do with multiphase flow model (reactingParcelFIlmFoam, interPhaseChangeFoam). Does anybody know how to do it? Thank you very much, Best regards, Miki |
May 5, 2014, 10:34 |
Rep Power: 12 |
Hello everybody,
Nobody knows how to do? Any insight will be very helpful! Thank you so much, Best regards, Miki |
May 21, 2015, 11:21 |
Jordi
Rep Power: 11 |
I have a similar problem, does anybody knows how to solve?
Thanks in advance! |
May 22, 2015, 04:51 |
A reference paper hint
Andrea Petronio
Rep Power: 17 |
Dear all,
we developed a specific solver for this problem , including evaporation and condensation effect, with conjugate heat transfer. You can find the model explained in "P. Sosnowski, A. Petronio, V. Armenio, Numerical model for thin liquid film with evaporation and condensation on solid surfaces in systems with conjugated heat transfer, International Journal of Heat and Mass Transfer 66 (2013) 382–395". Hope it helps Andrea |
April 18, 2017, 13:03 |
#5 | |
sandy
Rep Power: 15 |
I am trying to implement the above suggested paper model in OpenFOAM. It will be really helpful if you can let me know about its validation performance. I understand that you might have done more validation of the model mentioned in paper. Please let me how did this model performed w.r.t to your test case. The paper only deals with a laminar flow int the pipe where it is comparing its result with experimental finding. Please let us know if you have more comparison. Thank you |
April 19, 2017, 05:56 |
more works done with the model
#6 | |
Andrea Petronio
Rep Power: 17 |
yes we worked a lot on this model. If your're interested in a turbulent flow have a look to: Cintolesi, Petronio, Armenio, "Large eddy simulation of turbulent buoyant flow in a confined cavity with conjugate heat transfer"Physics of Fluids 27(9): September 2015 DOI: 10.1063/1.4930815 and Cintolesi, Petronio, Armenio,"Large-eddy simulation of thin film evaporation and condensation from a hot plate in enclosure: First order statistics", International Journal of Heat and Mass Transfer 101:1123-1137 · October 2016 DOI: 10.1016/j.ijheatmasstransfer.2016.06.006. The paper with second order statistics analysis is under review. Moreover we introduced the radiation modeling in the CHT model as you can check in Cintolesi, Nilsson, Petronio, Armenio, "Numerical simulation of conjugate heat transfer and surface radiative heat transfer using the P1 thermal radiation model: Parametric study in benchmark cases",International Journal of Heat and Mass Transfer 107(April 2017):956–971 April 2017 DOI: 10.1016/j.ijheatmasstransfer.2016.11.006. Hope it helps! |
April 20, 2017, 06:15 |
#7 | |
sandy
Rep Power: 15 |
Allow me to ask for on one more help if it is possible for you. If there are no copyright issue, will you be able to share the code that you have implemented in OpenFOAM. it will be a great help to take the study further. Please let me know your thought. Thanks and Regards Sandip |
October 30, 2024, 06:35 |
#8 | |
Suhan Umur Okuducu
Rep Power: 2 |
Which one of these could be done with OpenFOAM-12? |
modeling condensation in humid air... | a.mashayekh | FLUENT | 9 | May 7, 2015 20:12 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
