April 25, 2014, 10:48 |
pimplefoam
amir
Rep Power: 12 |
hi
I have questions regarding solver pimplefoam.I want to solve TJunction. 1. Which problems can be solved with pimpleFoam? What is important in solving this kind of problem? 2. What are the inlets and outlets solver? Last edited by amirhnp; April 27, 2014 at 02:42. |
April 26, 2014, 22:53 |
#2 | |
Andrew Somorjai
Rep Power: 13 |
"Large time-step transient solver for incompressible, flow using the PIMPLE (merged PISO-SIMPLE) algorithm" transient means non-steady state with respect to time so some variables in the system change like pressure and temperature. TJunction is a tutorial and on linux you would just type blockMesh and then pimpleFoam. 2. Not sure what you mean, did you mean inlet? outlet? I'm pretty sure all the foam solvers are capable of systems with an inlet and outlet. |
April 27, 2014, 02:40 |
#3 | |
amir
Rep Power: 12 |
yes , inlet and outlet. thank you , mr Somorjai. |
pimpleFoam initialization? | TBERGE | OpenFOAM Running, Solving & CFD | 2 | April 2, 2014 09:20 |
Restarting with pimpleFoam | deinstein | OpenFOAM | 9 | November 27, 2013 09:53 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
Understanding pimpleFoam convergence criterion | Nucleophobe | OpenFOAM Running, Solving & CFD | 0 | March 13, 2013 19:46 |
Differences simpleFoam vs. pimpleFoam / RASModel.H vs turbulenceModel.H | uli | OpenFOAM Programming & Development | 7 | January 26, 2013 16:01 |
