rhocentralFoam Diverges!!?
Like Tree2Likes
  • 1 Post By lfgmarc
  • 1 Post By alexeym
Old   April 16, 2014, 04:56
Default rhocentralFoam Diverges!!?
Sasan Ghomi
sasanghomi is on a distinguished road
Hi Dear Foamers,
I have a problem about using rhocentralFoam. I uploaded a simple case. I want to simulate the compressible fluid flow around an object, But the case diverges very soon.
Please take a look at my simple case and please guide me.
Error text :
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
    From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>::T(double, double, double, double (Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>::*)(double) const) const in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoCentralFoam"
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Aborted (core dumped)
the velocity and pressure boundary conditions :
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (173.5943547 0 0);
boundaryField
  inlet
    type freestream;
    freestreamValue uniform (173.5943547 0  0);
  body
   type         fixedValue;
   value        uniform (0 0 0);
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101325;
boundaryField
body
   type          zeroGradient;
   inlet
   type         fixedValue;
   value        uniform 101325;
Link of my case :
https://mega.co.nz/#!s9BGgD6S!ebEc0x...N75tYYZSPZ3lbM
I appreciate any help from you.
Thanks and best regards,
Sasan.
sasanghomi is offline   Reply With Quote
Old   April 17, 2014, 03:12
lfgmarc's Avatar
Luis Felipe Gutierrez Marcantoni
lfgmarc is on a distinguished road
Send a message via MSN to lfgmarc
Hi, in my personal expertise this problem come from with the convergence of the iterative method utilized to calculate temperature from energetic variable. I suggest check your boundary conditions.
Regards,
Felipe
Felipe G
lfgmarc is offline   Reply With Quote
Old   April 17, 2014, 04:49
Sasan Ghomi
Dear Felipe, Thanks for your reply. Do you have any suggestions about boundary conditions? Is it possible to take a look at my case?
I appreciate your help
Best regards
Sasan.
Old   April 17, 2014, 05:42
lfgmarc's Avatar
Hi, Give me some time and I will review your case.
Regards.
sasanghomi likes this.
Felipe G
Old   April 17, 2014, 08:57
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
I've tried to run your case (ignoring rather interesting BCs) the reason for divergence is rather large initial time step. I've changed it to 1e-9 and everything started running. After several time steps value of dt stabilizes at
Mean and max Courant Numbers = 0.00928758543141 0.200031474414
deltaT = 3.71688375776e-08
Time = 2.90508688931e-06
Also I've decreased tolerances in fvSolution (down to 1e-8).
hsmao likes this.
alexeym is offline   Reply With Quote
Old   April 19, 2014, 03:38
Sasan Ghomi
Hi Alexey
Thank you very much for your guidance. As you said, The initial time step was large. I hope not to occur a new error in my simulation!
Sasan.
rhoCentralFoam transport equation JoaoDMiranda OpenFOAM Programming & Development 29 July 5, 2024 09:38
how to make rhoCentralFoam to write continuity residuals? immortality OpenFOAM Running, Solving & CFD 6 April 18, 2018 04:56
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 09:00
calculate a nozzle flow using rhoCentralFoam hg2lf OpenFOAM 0 October 25, 2012 22:26
rhoCentralFoam solver with Slip BCs fails in Parallel Only JLight OpenFOAM Running, Solving & CFD 2 October 11, 2012 22:08
