about control the debug information
Like Tree1Likes
  • 1 Post By wyldckat
Old   April 11, 2014, 08:50
Post about control the debug information
xuhe-openfoam
bieshuxuhe is on a distinguished road
hi !
I have modified DebugSwitches in the " etc/controlDict “ file ,but I don't know what to compile to make the modification come into effect !
I wonder if I have to Allwmake the OpenFOAM again ? it will take long !
could you help me ?
thanks.
bieshuxuhe is offline   Reply With Quote
Old   April 11, 2014, 13:21
xuhe-openfoam
hello,
for example ,I change the DebugSwitches { ...}
from
"lduMatrix 1;"
to
"lduMatrix 2;"
in the "OpenFOAM/OpenFOAM-2.2.0/etc/controlDict"
then, I run the dambreak case using interFoam , but I don't find more information print out in the terminal .
I wonder if I should do something to make sure the setting about lduMatrix to become
effect
thank you!
Old   April 11, 2014, 23:41
xuhe-openfoam
hello!
when i use openfoam-2.1.x , i could get residuals of every iteration by modifying the DebugSwitches in the " etc/controlDict “ file:
from
"lduMatrix 1;"
to
"lduMatrix 2;"
but now it doesn't work for openfoam-2.2.x !
how could I get residuals of every iteration from the terminal ? could you help me ?
thanks.
Old   April 13, 2014, 17:32
Retired Super Moderator
Bruno Santos
Greetings bieshuxuhe,
I vaguely remember someone asking and writing about this the other day... I went looking and I only found these two threads:
OK, looks like the output you're looking for is achieved with setting this instead:
SolverPerformance   2;
This is because in OpenFOAM 2.1.x, the test was done here:
src/OpenFOAM/matrices/lduMatrix/lduMatrix/lduMatrixTests.C
while in OpenFOAM 2.2.x, it's done here:
src/OpenFOAM/matrices/LduMatrix/LduMatrix/SolverPerformance.C
Best regards,
Bruno
hua1015 likes this.
Old   April 13, 2014, 22:16
xuhe-openfoam
thanks for your help !
debug information
ERROR #001100279 has occurred in subroutine ErrAction. smnaryal CFX 11 December 20, 2017 17:32
Problems of running Oscillating plate tutorial vovogoal CFX 20 February 4, 2016 08:03
error in two way fsi kmgraju CFX 1 May 2, 2011 03:32
Control Volume , Finite Volume, Finite Control Volume, Finite Element Method technocrat.prakash Main CFD Forum 1 April 24, 2010 20:24
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
