The results difference between parallel and serial run.
Like Tree1Likes
  • 1 Post By alexeym
Old   April 10, 2014, 02:07
Default The results difference between parallel and serial run.
Hkp
HK Park
Hkp is on a distinguished road
I'm working on developing a model of plasma jet flow for plasma cutting. I've attached figures of temperature distribution at the same time. They are the results of parallel and serial run.
As you can see the figures, the unphysical temperature is seen at the interface between subdomains for parallel run. As time goes on the simulation by parallel run blows up. For the results of one processor run(serial run), the temperature distribution looks good.
Scotch method is used for decomposition. I already checked the mesh quality but it is fine. I don't know what causes this problem. Do you have any idea about this problem?
HK
Hkp is offline   Reply With Quote
Old   April 16, 2014, 17:54
carsten fuetterer
carstenf is on a distinguished road
hi, i'm relatively new to OpenFoam and I didn't thought that there are problems in this way. interesting to know.
Did you play around with the hierarchicalCoeffs?
for example (2 2 1) which can be better than (4 1 1)
Maybe there are problems if the borders of the subdomains are on positions with high gradients
carstenf is offline   Reply With Quote
Old   April 17, 2014, 03:26
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Can you be more specific? Did you modify solver code (and BTW what solver?)? What modifications you did? What version of OpenFOAM do you use?
I can only guess that in your model you modify certain volume field with = operator and then forget to call correctBoundaryConditions method. Though the real reason can be elsewhere.
kmooney likes this.
alexeym is offline   Reply With Quote
decomposepar, openfoam 2.2.x, parallel computation
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 09:23
parallel run is slower than serial run (pimpleFoam) !!! mechy OpenFOAM 18 August 17, 2016 18:19
Big Difference Between serial run and parallel run case alundilong OpenFOAM Running, Solving & CFD 3 December 5, 2014 09:27
Big Difference Between Serial run and Parallel run case alundilong OpenFOAM Programming & Development 1 March 20, 2013 16:52
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 09:33
