compressibleInterFoam - Jet Impingement BCs
Like Tree1Likes
  • 1 Post By vigges
Old   April 3, 2014, 18:30
Default compressibleInterFoam - Jet Impingement BCs
vigges is on a distinguished road
Hello Foamers!
I'm trying to simulate a non-submerged oil jet impingement on a flat plate with compressibleInterFoam. As turbulence model, kOmegaSST is used. It's a 2D axisymmetric problem, so I use cyclic boundary conditions on the FRONT and BACK patch. As shown in the attached sketch, I initialize the upper reservoir so that it is filled with oil which has a velocity Uy = -0.7 m/s which corresponds to the volumetric flow rate specified by the flowRateInletVelocity boundary condition. The other boundary conditions are defined as follows:
inlet:
U | flowRateInletVelocity
p_rgh | zeroGradient
p | calculated
T | fixedValue
k | turbulentIntensityKineticEnergyInlet
omega | compressible::turbulentMixingLengthFrequencyInlet
outlet:
U | zeroGradient
p_rgh | fixedFluxPressure
p | calculated
T | zeroGradient
k | zeroGradient
omega | zeroGradient
walls & bottom:
U | zeroGradient
p | calculated
T | fixedValue
k | fixedValue
omega | compressible::omegaWallFunction;
Well, after hours of simulation, I was glad seeing the oil phase flowing almost as expected. When looking at the velocity & k distributions, there are regions of high values outside oil jet which I did not expect. The region of high k values more or less stays at the same position over several time steps, the region of high velocity is moving up and down periodically.
I was wondering if it has someting to do with my boundary conditions. Maybe somebody has experience with something like that. Before I start 'playing' around with the fvSchemes file, I'd like to make sure it's not something more easier to fix ;-)
Thank you :)
Andres_Aguirre3 likes this.
vigges is offline   Reply With Quote
Old   April 4, 2014, 06:34
Olivier
olivierG is on a distinguished road
hello,
You set a zeroGradient for the outlet velocity. This is clearly not true here. So
- extend the outlet enough that the zeroGradient is ok.
- try another BC: inletOutlet, ...
regards,
olivier
olivierG is offline   Reply With Quote
Old   June 14, 2020, 23:23
Andres Aguirre
Andres_Aguirre3 is on a distinguished road
Dude, I am trying to model a similar case, I am using compressibleInterForam as turbulent flow (KomegaSST) and I have a lot of problems and errors and I think I am incorrectly constructing the "FvSolution and FvSchemes" files.
Do you think you can share your case to guide me or help me with these two files to know how to place them correctly?
Thank you.
Andres_Aguirre3 is offline   Reply With Quote
Jet impingement on cylindrical obstacles robmuggleton FLUENT 1 October 21, 2013 19:08
Supersonic Jet Impingement over a flat plate Smaras FLUENT 3 June 7, 2013 04:55
HELP: jet impingement heat transfer Student8X FLUENT 0 July 18, 2011 10:01
Water Jet Impingement Ahmed Omar CFX 0 April 13, 2006 19:20
JET IMPINGEMENT G.Balakrishnan FLUENT 1 December 9, 2000 13:17
