How to add a passive scalar to the simpleFoam solver
Like Tree11Likes
  • 7 Post By Uyan
  • 1 Post By Sugajen
  • 1 Post By tas38
  • 2 Post By Uyan
Old   March 13, 2014, 17:18
Default How to add a passive scalar to the simpleFoam solver
Uyan is on a distinguished road
Hi all,
I am new to OpenFOAM software. I ran a simulation of a Jet in a crossflow simulation using simpleFoam. I need to add a passive scalar transportation equation to the simpleFoam solver.
I went through the following example.
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
But my problem of including passive scalar transportation equation with a turbulent Schmidt number is slightly different from this example.
So, How do I add a passive scalar transport equation to the simpleFoam solver?
Appreciate any guidance on this issue.
Thank you.
Uyan is offline   Reply With Quote
Old   February 20, 2015, 13:50
Default For anyone searching for the solution for this problem.
For anyone who is trying to solve a problem like this i am posting the method i followed.
create a TEqn as of other UEqn and PEqn for the passive scalar.
    volScalarField kappaEff
        "kappaEff",
         (turbulence->nut()/Prt) +(turbulence->nu()/Pr)
    fvScalarMatrix TEqn
      fvm::div(phi, T)
      - fvm::laplacian(kappaEff, T)
    TEqn.relax();
    TEqn.solve();
Then add the T field into createFields.H header file.
    Info<< "Reading field T\n" <<endl;
    volScalarField T
      IOobject
         "T",
         runTime.timeName(),
         mesh,
         IOobject::MUST_READ,
         IOobject::AUTO_WRITE
      mesh
Then include the TEqn into simpleFoam.C after turbulence correction.
         turbulence->correct();
          #include "TEqn.H"
Then add a line to read turbulent Prandtl number from transportProperties dictionary.
   singlePhaseTransportModel laminarTransport(U, phi);
     dimensionedScalar Pr(laminarTransport.lookup("Pr"));
     dimensionedScalar Prt(laminarTransport.lookup("Prt"));
Don't forget to rename simpleFoam.C and the change Make/files to get a new application.
This example was also useful.
https://openfoamwiki.net/index.php/H...ure_to_icoFoam
Old   June 21, 2017, 22:04
Default Solution diverging
Sugajen
Sugajen is on a distinguished road
Hi all,
I followed the procedure as posted by Uyan and found that the scalar transport solution diverging. But the scalar is transported throughout the region as expected. What could be the cause of divergence? It does not make sense to me since the solution looks acceptable, it is the divergence bothering me Below is the output from OF, fvSchemes, fvSolution and U BC. Attached are the solver and case files.
All comments and suggestions are welcome
output
Time = 101
smoothSolver:  Solving for Ux, Initial residual = 0.00120042, Final residual = 3.7046e-06, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 0.00120393, Final residual = 3.70971e-06, No Iterations 4
smoothSolver:  Solving for Uz, Initial residual = 0.000836939, Final residual = 2.79653e-06, No Iterations 4
GAMG:  Solving for p, Initial residual = 4.31652e-05, Final residual = 8.86733e-07, No Iterations 9
time step continuity errors : sum local = 3.83691e-06, global = 4.17804e-07, cumulative = 0.00012566
GAMG:  Solving for CF, Initial residual = 0.685496, Final residual = 0.513947, No Iterations 1000
ExecutionTime = 211.28 s  ClockTime = 212 s
    From function virtual bool Foam::regIOobject::readIfModified()
    in file db/regIOobject/regIOobjectRead.C at line 291
    Re-reading object controlDict from file "/home/ipalab/OpenFOAM/ipalab-4.1/simplefoamexample/system/controlDict"
Time = 102
smoothSolver:  Solving for Ux, Initial residual = 0.00118109, Final residual = 3.65892e-06, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 0.001184, Final residual = 3.66113e-06, No Iterations 4
smoothSolver:  Solving for Uz, Initial residual = 0.000818525, Final residual = 2.73043e-06, No Iterations 4
GAMG:  Solving for p, Initial residual = 4.16364e-05, Final residual = 8.8246e-07, No Iterations 9
time step continuity errors : sum local = 3.81498e-06, global = 4.26037e-07, cumulative = 0.000126086
GAMG:  Solving for CF, Initial residual = 0.684755, Final residual = 0.514736, No Iterations 1000
ExecutionTime = 214.31 s  ClockTime = 215 s
fvScheme
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwind grad(U);
    div(phi,nuTilda) bounded Gauss linearUpwind grad(nuTilda);
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
    div(phi,CF)      bounded Gauss linearUpwind grad(CF);
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
fvSolution
solvers
    p
        solver          GAMG;
        tolerance       1e-06;
        relTol          0.01;
        smoother        GaussSeidel;
    CF
        solver          GAMG;
        tolerance       1e-06;
        relTol          0.01;
    U
        solver          smoothSolver;
        nSweeps         2;
        tolerance       1e-08;
        relTol          0.01;
    nuTilda
        nSweeps         2;
        tolerance       1e-08;
        relTol          0.01;
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
    residualControl
        p               1e-5;
        U               1e-5;
        nuTilda         1e-5;
	CF		1e-5;
relaxationFactors
    fields
        p               0.3;
	CF		0.3;
    equations
        U               0.7;
        nuTilda         0.7;
U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0.0 0.0 0.1);
boundaryField
    inlet
        type            fixedValue;
        value		uniform (0.0 0.0 0.1);
    outlet
        type            zeroGradient;
    xWalls
        type            noSlip;
    yWalls
        type            noSlip;
File Type: txt turbulenceProperties.txt (991 Bytes, 31 views)
cathaygrace likes this.
Sugajen is offline   Reply With Quote
Old   June 22, 2017, 11:37
Troy Snyder
tas38 is on a distinguished road
Does your solution diverge using the original application, i.e. without transport of the passive scalar? This is the first thing I would check.
watermelon likes this.
tas38 is offline   Reply With Quote
Old   June 22, 2017, 13:32
Sugajen,
I think, how do you calculate diffusion term coefficient DS is the problem here.
Change the DS value and see how it affects the solver performance then you'll see it depends on DS value.
But why do you use a user defined diffusion coefficient in the first place?
If you look at my post #2,you'll see i have used the diffusion coefficient as a function of eddy viscosity.
Old   June 22, 2017, 15:58
Sugajen
@Uyan I have constant diffusion coefficient. That is why making it user defined. But why would that matter?
@tas38 That's a good point. It does converge with simpleFoam
Old   June 22, 2017, 18:36
Sugen,
In my case i did not relax scalar equation , i simply solved the pressure velocity loop and then using that velocity i solved the scalar.
Even if i had used TEqn.relax() in the above code, i have not under relaxed the field. So it was a redundant statement.
Try without under relaxing. No need to under-relax a passive scalar.
Sugajen and watermelon like this.
passive scalar, schmidt, simplefoam
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
passive scalar with simpleFoam Uyan OpenFOAM Programming & Development 2 March 1, 2016 11:07
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
Climbing inlet pressure with simpleFoam and directMappedPatches chegdan OpenFOAM Running, Solving & CFD 1 January 2, 2012 20:35
