Problem with cyclic boundary conditions in parallel |
March 4, 2014, 09:36 |
ttttoor
Rep Power: 12 |
Hi, all
I am simulating a fluid flow in a periodic cylinder pipe using OpenFOAM. The 0/U and 0/p files are set as following: 0/U inlet { type cyclic; value uniform (0 0 0); } outlet { type cyclic; value uniform (0 0 0); } wall { type fixedValue; value uniform (0 0 0); } 0/p inlet { type fan; patchType cyclic; f List 1 (-0.0128); value uniform 0; } outlet { type fan; patchType cyclic; f List 1 (-0.0128); value uniform 0; } wall { type zeroGradient; } It works well. But when I run the simulation in parallel, the pressure field and the velocity field become zero in the first time step. Do you have any idea for the reason? Thanks in advance. |
March 4, 2014, 11:26 |
Christian
Rep Power: 13 |
are you running the cyclic-patches on the same processor?i think you can fix the by editing the decomposition-file.
for example: method simple; preservePatches ( LEFT RIGHT ); |
March 6, 2014, 04:04 |
ttttoor
Rep Power: 12 |
February 5, 2019, 10:11 |
krishna kant
Rep Power: 10 |
Hello
I am working with cyclic boundary condition as well. The test case I am solving is a static bubble in a quiescent flow. It is a 2D case with all sides periodic i.e. left,right,top,bottom all. I am getting unphysical velocities at corners in parallel run after doing the modification as suggested Christian. U.jpg |
cyclic boundary, openfoam, parallel |
cyclic boundary conditions and moveMesh | gtg258f | OpenFOAM | 2 | November 21, 2013 10:13 |
Boundary Conditions problem | o_mars_2010 | Main CFD Forum | 2 | July 8, 2013 03:10 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
snnappyHexMesh with cyclic boundary conditions | longamon | OpenFOAM | 2 | May 9, 2011 13:28 |
Cyclic boundary conditions in parallel | thibault_pringuey | OpenFOAM Bugs | 1 | April 2, 2011 16:21 |
