simpleFoam error - "Floating point exception"
Like Tree1Likes
  • 1 Post By alexeym
Old   February 12, 2014, 11:17
Default simpleFoam error - "Floating point exception"
James
mbcx4jc2 is on a distinguished road
Hi everyone,
I'm running into an error running simpleFoam (this problem also happens with icoFoam).
Casefile can be found at the following address:
https://drive.google.com/file/d/0B5R...it?usp=sharing
I'm getting the error pasted below. The log file also reveals that the solution is diverging which I suspect why this is happening. checkMesh looks good, boundary conditions appear sensible. Any ideas would be much appreciated!
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
at simpleFoam.C:0
in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/simpleFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
mbcx4jc2 is offline   Reply With Quote
Old   February 12, 2014, 12:01
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Obviously you've got diverging solution. Look at all those 1001 in log file, it is default maximum number of iteration of the matrix solver after which it will give up even it doesn't get the solution within given tolerances.
I'm not quite get from the case files what you are trying to do but I've attached archive with the settings that can bear your setup. But the velocities in the narrow part of the mesh are around 4 km/s so I guess it doesn't make much sense.
I've attached only archive of the system folder as I've made no changes in other folders.
Mayitoalberto likes this.
alexeym is offline   Reply With Quote
Old   February 12, 2014, 13:53
James
Thanks alexeym!
It's running for me up to timestep 19.8 so obviously this is a big improvement. Basically, I'm just trying to measure permeability across this mesh by sampling pressure difference and flux through the two planes that are my inlets and outlets. Perhaps reducing the velocity bc at the inlet will reduce the absolute velocity in the narrow section but I imagine relatively speaking, the velocity would still be this high. Would reducing the initial velocity amount help the solution converge?
Old   February 12, 2014, 14:27
Alexey Matveichev
Well,
You can try to estimate velocity in the narrow part from cross-section areas ratio.
As you are trying to run simulation in laminar case, you should also estimate Reynolds number to see if it is really so.
And answering your question: yes, it will help.
Old   March 5, 2014, 22:59
Unhappy error:time step continuty errors increasing and diverged
Fengjiao Bian
jiaojiao is on a distinguished road
Originally Posted by mbcx4jc2 View Post
Hi everyone,
at simpleFoam.C:0
I have a similar problem,I am running the MRFSimplefoam with of2.1 to simulate the 3D wind turbine, but it cause an error as I pasted
#0  Foam::error::printStack(Foam::Ostream&) in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#2  __restore_rt at sigaction.c:0
#3  Foam::writeFuns::insert(double, Foam::DynamicList<float, 0u, 2u, 1u>&) in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/foamToVTK"
#4  void Foam::writeFuns::write<double>(std::ostream&, bool, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::pointPatchField, Foam::pointMesh> const&, Foam::vtkMesh const&) in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/foamToVTK"
#5  void Foam::internalWriter::write<double>(Foam::volPointInterpolation const&, Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/foamToVTK"
#6  main in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/foamToVTK"
#7  __libc_start_main in "/lib64/libc.so.6"
#8  Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/foamToVTK"
浮点数例外
can anybody help me? Where the problems are and how can I fix it? my fvshemes file is
ddtSchemes
    default         steadyState;
gradSchemes
    default         cellLimited Gauss linear 1;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         Gauss upwind;
    div(phi,U)       Gauss limitedLinearV 1;//Gauss upwind;
    div(phi,k)       Gauss upwind;
    div(phi,epsilon)  Gauss upwind;//linear;
    div(phi,nuTilda) Gauss linearUpwind grad(nuTilda);
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
    laplacian(1,p)  Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
the log is
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.3;
No field sources present
SIMPLE: convergence criteria
    field p     tolerance 1e-05
    field U     tolerance 1e-05
    field nuTilda     tolerance 1e-05
Starting time loop
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0116175, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0478811, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0116854, No Iterations 2
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0747252, No Iterations 1
time step continuity errors : sum local = 1222.25, global = 625.783, cumulative = 625.783
smoothSolver:  Solving for epsilon, Initial residual = 0.999886, Final residual = 0.00670035, No Iterations 4
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.00694971, No Iterations 2
ExecutionTime = 39.72 s  ClockTime = 40 s
Time = 2
smoothSolver:  Solving for Ux, Initial residual = 0.255939, Final residual = 0.00653363, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.207718, Final residual = 0.00447832, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.253055, Final residual = 0.00686111, No Iterations 2
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.16482, No Iterations 1
time step continuity errors : sum local = 1507.88, global = 682.725, cumulative = 1308.51
smoothSolver:  Solving for epsilon, Initial residual = 0.36138, Final residual = 0.00191422, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.577132, Final residual = 0.00949441, No Iterations 2
ExecutionTime = 60.56 s  ClockTime = 66 s
Time = 3
smoothSolver:  Solving for Ux, Initial residual = 0.199729, Final residual = 0.00633206, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.27506, Final residual = 0.00436556, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.200162, Final residual = 0.00666538, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.486066, Final residual = 0.0946856, No Iterations 1
time step continuity errors : sum local = 824.775, global = 340.359, cumulative = 1648.87
smoothSolver:  Solving for epsilon, Initial residual = 0.298414, Final residual = 0.00162272, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.23253, Final residual = 0.00363581, No Iterations 2
ExecutionTime = 80.71 s  ClockTime = 86 s
Time = 4
smoothSolver:  Solving for Ux, Initial residual = 0.206463, Final residual = 0.00682647, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.447125, Final residual = 0.00887106, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.206458, Final residual = 0.00696421, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.443974, Final residual = 0.0504603, No Iterations 1
time step continuity errors : sum local = 661.598, global = -177.288, cumulative = 1471.58
smoothSolver:  Solving for epsilon, Initial residual = 0.432129, Final residual = 0.00656384, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.43187, Final residual = 0.00188758, No Iterations 2
ExecutionTime = 101.48 s  ClockTime = 112 s
Time = 5
smoothSolver:  Solving for Ux, Initial residual = 0.180274, Final residual = 0.00628132, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.279662, Final residual = 0.00753944, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.181797, Final residual = 0.00637471, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.615593, Final residual = 0.0888842, No Iterations 1
time step continuity errors : sum local = 1278.21, global = -675.965, cumulative = 795.615
smoothSolver:  Solving for epsilon, Initial residual = 0.310979, Final residual = 0.00371577, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.273199, Final residual = 0.00232058, No Iterations 2
ExecutionTime = 123.77 s  ClockTime = 134 s
Time = 6
smoothSolver:  Solving for Ux, Initial residual = 0.134419, Final residual = 0.00424664, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.13053, Final residual = 0.00380063, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.135395, Final residual = 0.00435766, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.784403, Final residual = 0.141384, No Iterations 1
time step continuity errors : sum local = 1529.09, global = -741.707, cumulative = 53.9077
smoothSolver:  Solving for epsilon, Initial residual = 0.231691, Final residual = 0.00282583, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.166224, Final residual = 0.00223461, No Iterations 2
ExecutionTime = 145.56 s  ClockTime = 161 s
Time = 7
smoothSolver:  Solving for Ux, Initial residual = 0.136914, Final residual = 0.00399246, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.105305, Final residual = 0.00289856, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.13624, Final residual = 0.00405558, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.721444, Final residual = 0.143873, No Iterations 1
time step continuity errors : sum local = 1409.36, global = -557.136, cumulative = -503.228
smoothSolver:  Solving for epsilon, Initial residual = 0.209118, Final residual = 0.0031759, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.156912, Final residual = 0.00272508, No Iterations 2
ExecutionTime = 167.51 s  ClockTime = 183 s
Time = 8
smoothSolver:  Solving for Ux, Initial residual = 0.142662, Final residual = 0.00416516, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.106274, Final residual = 0.0027194, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.142317, Final residual = 0.00423871, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.50711, Final residual = 0.0923087, No Iterations 1
time step continuity errors : sum local = 1146.77, global = -448.292, cumulative = -951.52
smoothSolver:  Solving for epsilon, Initial residual = 0.225749, Final residual = 0.00427787, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.174881, Final residual = 0.00347794, No Iterations 2
ExecutionTime = 189.73 s  ClockTime = 210 s
Time = 9
smoothSolver:  Solving for Ux, Initial residual = 0.132193, Final residual = 0.00415394, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.0937998, Final residual = 0.00250987, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.133503, Final residual = 0.00419109, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.41403, Final residual = 0.0826546, No Iterations 1
time step continuity errors : sum local = 1231.54, global = -483.631, cumulative = -1435.15
smoothSolver:  Solving for epsilon, Initial residual = 0.238165, Final residual = 0.00537919, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.18193, Final residual = 0.00424883, No Iterations 2
ExecutionTime = 211.34 s  ClockTime = 232 s
Time = 10
smoothSolver:  Solving for Ux, Initial residual = 0.114206, Final residual = 0.00371409, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.0774936, Final residual = 0.00227964, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.116838, Final residual = 0.00371665, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.390742, Final residual = 0.0831381, No Iterations 1
time step continuity errors : sum local = 1287.78, global = -275.8, cumulative = -1710.95
smoothSolver:  Solving for epsilon, Initial residual = 0.203471, Final residual = 0.00501127, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.169364, Final residual = 0.00457364, No Iterations 2
ExecutionTime = 233.55 s  ClockTime = 259 s
Time = 11
smoothSolver:  Solving for Ux, Initial residual = 0.103788, Final residual = 0.00356374, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.0637353, Final residual = 0.00211766, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.104148, Final residual = 0.0034536, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.380292, Final residual = 0.0869304, No Iterations 1
time step continuity errors : sum local = 1302.78, global = -205.145, cumulative = -1916.1
smoothSolver:  Solving for epsilon, Initial residual = 0.160339, Final residual = 0.00424108, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.14831, Final residual = 0.00447062, No Iterations 2
ExecutionTime = 255.03 s  ClockTime = 281 s
Time = 12
smoothSolver:  Solving for Ux, Initial residual = 0.0950877, Final residual = 0.0033789, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.0547081, Final residual = 0.0018934, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.0942434, Final residual = 0.00320187, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.36055, Final residual = 0.0855903, No Iterations 1
time step continuity errors : sum local = 1272.49, global = -177.985, cumulative = -2094.08
smoothSolver:  Solving for epsilon, Initial residual = 0.141591, Final residual = 0.0039718, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.139064, Final residual = 0.00437892, No Iterations 2
ExecutionTime = 276.63 s  ClockTime = 307 s
Time = 13
smoothSolver:  Solving for Ux, Initial residual = 0.08845, Final residual = 0.00326364, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.0481885, Final residual = 0.00174469, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.0879515, Final residual = 0.00315651, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.346286, Final residual = 0.081073, No Iterations 1
time step continuity errors : sum local = 1200.51, global = -165.516, cumulative = -2259.6
smoothSolver:  Solving for epsilon, Initial residual = 0.13731, Final residual = 0.00392148, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.13561, Final residual = 0.0043371, No Iterations 2
ExecutionTime = 296.61 s  ClockTime = 327 s
Time = 14
smoothSolver:  Solving for Ux, Initial residual = 0.0826409, Final residual = 0.00302597, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.0436394, Final residual = 0.0016168, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.0823954, Final residual = 0.00302672, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.334584, Final residual = 0.0735457, No Iterations 1
time step continuity errors : sum local = 1086.94, global = -161.867, cumulative = -2421.46
smoothSolver:  Solving for epsilon, Initial residual = 0.13495, Final residual = 0.00391054, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.134138, Final residual = 0.00437452, No Iterations 2
ExecutionTime = 316.77 s  ClockTime = 354 s
Time = 15
smoothSolver:  Solving for Ux, Initial residual = 0.0779784, Final residual = 0.00287186, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.0403581, Final residual = 0.00151513, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.0772994, Final residual = 0.00287905, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.329316, Final residual = 0.0656906, No Iterations 1
time step continuity errors : sum local = 972.644, global = -160.998, cumulative = -2582.46
smoothSolver:  Solving for epsilon, Initial residual = 0.134529, Final residual = 0.0038749, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.139388, Final residual = 0.00462282, No Iterations 2
ExecutionTime = 338.2 s  ClockTime = 375 s
Time = 16
smoothSolver:  Solving for Ux, Initial residual = 0.075164, Final residual = 0.00285694, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.038141, Final residual = 0.00143983, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.0761046, Final residual = 0.00311105, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.325418, Final residual = 0.0581975, No Iterations 1
time step continuity errors : sum local = 870.478, global = -83.0109, cumulative = -2665.47
smoothSolver:  Solving for epsilon, Initial residual = 0.439395, Final residual = 0.0130362, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.552394, Final residual = 0.0347422, No Iterations 2
ExecutionTime = 359.51 s  ClockTime = 402 s
Time = 17
smoothSolver:  Solving for Ux, Initial residual = 0.464726, Final residual = 0.00644288, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 0.129872, Final residual = 0.00153488, No Iterations 4
smoothSolver:  Solving for Uz, Initial residual = 0.773062, Final residual = 0.0125177, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.720437, Final residual = 0.12145, No Iterations 1
time step continuity errors : sum local = 4831.8, global = -1203.49, cumulative = -3868.96
smoothSolver:  Solving for epsilon, Initial residual = 0.99852, Final residual = 0.0378969, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 0.99975, Final residual = 0.000130416, No Iterations 4
ExecutionTime = 381.33 s  ClockTime = 424 s
Time = 18
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.00994666, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0101358, No Iterations 4
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0100816, No Iterations 4
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.28906, No Iterations 2
time step continuity errors : sum local = 1.85649e+11, global = -7.84046e+10, cumulative = -7.84047e+10
smoothSolver:  Solving for epsilon, Initial residual = 1, Final residual = 0.0601755, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.0695155, No Iterations 2
ExecutionTime = 403.73 s  ClockTime = 446 s
Time = 19
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.00701573, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.00701791, No Iterations 4
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0070213, No Iterations 4
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.203189, No Iterations 2
time step continuity errors : sum local = 2.55152e+32, global = 1.23564e+32, cumulative = 1.23564e+32
smoothSolver:  Solving for epsilon, Initial residual = 1, Final residual = 0.0624321, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.0115553, No Iterations 2
ExecutionTime = 426 s  ClockTime = 468 s
Time = 20
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.00687755, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.00687755, No Iterations 4
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.00687755, No Iterations 4
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.246173, No Iterations 7
time step continuity errors : sum local = 3.63847e+82, global = 9.72572e+81, cumulative = 9.72572e+81
smoothSolver:  Solving for epsilon, Initial residual = 1, Final residual = 0.00747124, No Iterations 8
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 5.54463e-06, No Iterations 2
ExecutionTime = 454.86 s  ClockTime = 497 s
when it run to steps21,the errors take placed.
jiaojiao is offline   Reply With Quote
Old   March 6, 2014, 01:05
Bin Xu
norkistar is on a distinguished road
your first step : time step already diverge, you can have a check about your mesh and your boundary condition settings
norkistar is offline   Reply With Quote
Old   March 7, 2014, 03:55
Fengjiao Bian
i run checkMesh and it shows:
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 6657993
internal faces: 6626605
cells: 3261204
faces per cell: 4.07353
boundary patches: 4
point zones: 0
face zones: 1
cell zones: 2
Overall number of cells of each type:
hexahedra: 100740
prisms: 3984
wedges: 0
pyramids: 34318
tet wedges: 0
tetrahedra: 3122162
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
blade 24146 21942 ok (closed singly connected)
inlet 1841 966 ok (non-closed singly connected)
outlet 1841 966 ok (non-closed singly connected)
symmetry 3560 3649 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-12.7106 -6.66098 -12.7139) (12.7102 27.7695 12.7057)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-2.3031e-15 -3.09845e-16 5.48772e-16) OK.
Max cell openness = 1.07338e-15 OK.
Max aspect ratio = 30.0527 OK.
Minimum face area = 6.8698e-07. Maximum face area = 0.772395. Face area magnitudes OK.
Min volume = 3.21357e-10. Max volume = 0.154152. Total volume = 17466.7. Cell volumes OK.
Mesh non-orthogonality Max: 70.2416 average: 19.945
*Number of severely non-orthogonal (> 70 degrees) faces: 3.
Non-orthogonality check OK.
<<Writing 3 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 3.90819 OK.
Coupled point location match (average 0) OK.
Mesh OK.
how ablout the mesh quality? if bad,does the problem lie in the volume range or the 3 non-orthogonal faces or something eles?
Old   March 13, 2014, 21:09
Fengjiao Bian
Hi,I now use Gambit to generate mesh, boundary condition doesnt change and it can run more than 150 steps with the first time steps continuty errors OK. I paste the log file,could you tell me where the problem is?the eorror messege is
#3  Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#4  Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#6  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libfiniteVolume.so"
#8  Foam::fvMatrix<double>::solve() in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/MRFSimpleFoam"
#9  main in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/MRFSimpleFoam"
#10  __libc_start_main in "/lib64/libc.so.6"
#11  Foam::UOPstream::write(char) in "/home/user5/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/MRFSimpleFoam"
娴偣鏁颁緥澶
Old   March 13, 2014, 21:14
Fengjiao Bian
It seems the log file didnt upload, I am so confused. I can only cut the part where error happens.
Time = 75
smoothSolver: Solving for Ux, Initial residual = 0.0602954, Final residual = 0.00373723, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.0653118, Final residual = 0.00486974, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.0597028, Final residual = 0.00373956, No Iterations 2
GAMG: Solving for p, Initial residual = 9.91772e-08, Final residual = 9.91772e-08, No Iterations 0
time step continuity errors : sum local = 0.508126, global = -0.00403281, cumulative = 0.0725249
smoothSolver: Solving for epsilon, Initial residual = 0.111438, Final residual = 2.47159e-07, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.0644941, Final residual = 0.00196909, No Iterations 2
ExecutionTime = 1101.44 s ClockTime = 1104 s
Time = 76
smoothSolver: Solving for Ux, Initial residual = 0.0594781, Final residual = 0.00349262, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.060454, Final residual = 0.00433672, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.0589499, Final residual = 0.00349089, No Iterations 2
GAMG: Solving for p, Initial residual = 9.85788e-08, Final residual = 9.85788e-08, No Iterations 0
time step continuity errors : sum local = 0.536801, global = -0.00461372, cumulative = 0.0679112
smoothSolver: Solving for epsilon, Initial residual = 0.119377, Final residual = 1.54768e-07, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.0767105, Final residual = 0.00221075, No Iterations 2
ExecutionTime = 1115.63 s ClockTime = 1118 s
Time = 77
smoothSolver: Solving for Ux, Initial residual = 0.0592163, Final residual = 0.00329118, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.0563358, Final residual = 0.00385813, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.0588684, Final residual = 0.00329036, No Iterations 2
GAMG: Solving for p, Initial residual = 9.65561e-08, Final residual = 9.65561e-08, No Iterations 0
time step continuity errors : sum local = 0.565758, global = -0.00525311, cumulative = 0.0626581
smoothSolver: Solving for epsilon, Initial residual = 0.124077, Final residual = 9.12524e-08, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.0872853, Final residual = 0.00261114, No Iterations 2
ExecutionTime = 1129.82 s ClockTime = 1133 s
Time = 78
smoothSolver: Solving for Ux, Initial residual = 0.0601651, Final residual = 0.00311845, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.0534155, Final residual = 0.00342506, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.0595368, Final residual = 0.0031283, No Iterations 2
GAMG: Solving for p, Initial residual = 9.28703e-08, Final residual = 9.28703e-08, No Iterations 0
time step continuity errors : sum local = 0.594105, global = -0.00596336, cumulative = 0.0566947
smoothSolver: Solving for epsilon, Initial residual = 0.130123, Final residual = 5.31763e-08, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.0996443, Final residual = 0.00317308, No Iterations 2
bounding k, min: -27.2023 max: 6.08394e+06 average: 47.9263
ExecutionTime = 1144.26 s ClockTime = 1147 s
Time = 79
smoothSolver: Solving for Ux, Initial residual = 0.0614544, Final residual = 0.00297322, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.0514696, Final residual = 0.00306002, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.0607817, Final residual = 0.00298804, No Iterations 2
GAMG: Solving for p, Initial residual = 8.84393e-08, Final residual = 8.84393e-08, No Iterations 0
time step continuity errors : sum local = 0.620817, global = -0.00674595, cumulative = 0.0499488
smoothSolver: Solving for epsilon, Initial residual = 0.13737, Final residual = 2.93949e-08, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.113938, Final residual = 0.00343359, No Iterations 2
bounding k, min: -216.755 max: 8.91232e+06 average: 61.9746
ExecutionTime = 1158.68 s ClockTime = 1161 s
Time = 80
smoothSolver: Solving for Ux, Initial residual = 0.063004, Final residual = 0.00283814, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.0505971, Final residual = 0.00273304, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.0624865, Final residual = 0.0028546, No Iterations 2
GAMG: Solving for p, Initial residual = 8.29655e-08, Final residual = 8.29655e-08, No Iterations 0
time step continuity errors : sum local = 0.645584, global = -0.00760253, cumulative = 0.0423462
smoothSolver: Solving for epsilon, Initial residual = 0.143916, Final residual = 1.66331e-08, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.127062, Final residual = 0.00356757, No Iterations 2
bounding k, min: -19.5544 max: 1.31047e+07 average: 81.9192
ExecutionTime = 1173.05 s ClockTime = 1176 s
Old   April 21, 2015, 14:35
Default Floating point exception (core dumped)- Immersed boundary- simpleIbFoam
Anamitra Bagchi
Anamitra is on a distinguished road
Hi I am using simpleIbFoam, each time I run it shows this error. The checkMesh looks ok. Can someone help with this issue ? Thanks in advance !!
anamitra@anamitra-HP-Pavilion-g6-Notebook-PC:~/IC_Files/Empty_Domain/simpleibfoam_vg$ simpleIbFoam
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 3.1 |
| \\ / A nd | Web: http://www.extend-project.de |
| \\/ M anipulation | |
Build : 3.1-7d8e040bf53d
Exec : simpleIbFoam
Date : Apr 21 2015
Time : 19:30:14
Host : anamitra-HP-Pavilion-g6-Notebook-PC
PID : 8630
CtrlDict : /home/anamitra/foam/foam-extend-3.1/etc/controlDict
Case : /home/anamitra/IC_Files/Empty_Domain/simpleibfoam_vg
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Reading field p
Reading field U
Selecting RAS turbulence model kOmegaSST
External flow
Number of IB cells: 76
kOmegaSSTCoeffs
alphaK1 0.85034;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.85616;
gamma1 0.5532;
gamma2 0.4403;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
c1 10;
Create immersed boundary cell mask
Create immersed boundary face mask
Found immersed boundary patch 0 named ibsimplevg
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 0.357069, Final residual = 0.000767327, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.999927, Final residual = 0.00105008, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.285562, Final residual = 0.000466337, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.984177, Final residual = 0.0909034, No Iterations 85
time step continuity errors : sum local = 0.175394, global = -0.00155391, cumulative = -0.00155391
Anamitra is offline   Reply With Quote
Old   April 21, 2015, 20:45
N/A
kamakura117 is on a distinguished road
Anamitra:
It looks like you need to double check your BCs and ICs.
Also, it's taking a lot of iterations to converge your pressure, you might consider a different numerical method if your BC/ICs are okay.
kamakura117 is offline   Reply With Quote
Old   June 25, 2015, 14:53
Anamitra Bagchi
Thanks for the reply!! Could you suggest what changes are possible in the boundary conditions, I am still looking for it.
I am not very sure what factors can cause the floating point exception. I am solving a case of external flow around a cuboid (with Immersed boundary) placed around the centre of the flow domain.
Pressure looks like this:
internalField nonuniform List<scalar>
256000
(long list found from mapping fields)
boundaryField
ibsimplevg
type immersedBoundary;
refValue uniform 0;
refGradient uniform 0;
fixesValue no;
setDeadCellValue yes;
deadCellValue 0;
value nonuniform 0();
inlet
type zeroGradient;
outlet
type zeroGradient;
sides
type symmetryPlane;
wall_plate
type zeroGradient;
top
type zeroGradient;
Old   August 4, 2015, 03:20
Ipos
Kittipos is on a distinguished road
Hi Foamer
I have an error with running rhoPorousSimpleFoam in my simple model.
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libfluidThermophysicalModels.so"
#4  Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libfluidThermophysicalModels.so"
 in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/rhoPorousSimpleFoam"
#6  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Thank you
Kittipos is offline   Reply With Quote
error, floating point exception, openfoam, simplefoam
problem in toposet Ahmed Khattab OpenFOAM Pre-Processing 27 March 3, 2023 22:12
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
3Dmixer on simpleFoam and MRFInterFoam. sharonyue OpenFOAM Running, Solving & CFD 1 May 12, 2013 02:04
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 01:37
CFX Post: Problems with moving point cloud for changing time steps spatialtime CFX 0 December 7, 2009 05:56
