Add ignition but combustion does not occur
Like Tree3Likes
  • 3 Post By babakflame
Old   January 14, 2014, 23:01
Default Add ignition but combustion does not occur
IColin is on a distinguished road
Hi, I am trying to do some simulation about the combustion of isooctane. I use reactingFoam which includes chemkin of isooctane. For the ignition, I add fvOptions in the system. The ignition during is 0.001s. However, the maximum temperature goes up during the ignition and goes down very quickly after the ignition which means no combustion occurs. So, could anyone gives me some advice how to deal with this problem. Thanks in advance.
IColin is offline   Reply With Quote
Old   January 18, 2014, 08:52
Bobby
babakflame is on a distinguished road
Greetings zhuguangfei
For having combustion, first you should clarify your combustion model in O.F.
If you are using PaSR model (I guess), Raise the temperature of the fuel stream upper than auto-ignition temperature, after starting the combustion, change it to normal temperature in the boundary condition of your T file. There is no need to use ignition.
Regards
Bobi
babakflame is offline   Reply With Quote
Old   January 18, 2014, 15:16
Thumbs up
Regards
Bobi
Hi, Bobi
First, thanks for your kind reply. My initial temperature is 330 K and the boundary condition is wall boundary. That means the mixture is homogeneous. Then I add an ignition (fvOptions). You are right that I choose PaSR combustion model. So,I just guess maybe the ignition duration is too small which means the diffusion overcomes the injection energy leading to extinguish. By the way, could you tell me the meaning of
injectionRateSuSp
h (10, 0)
in the fvOptions? Thanks so much.
Best Regards,
Colin
Old   January 19, 2014, 02:43
Bobby
Unfortunately, I don't use ignition for having combustion with PaSR combustion model. I think that is a source term for enthalpy in enthalpy equation that causes a sudden increase in temperature.
I think my suggestion was not enough transparent. After starting injecting your fuel stream with a Temp more than 2000 K , you will have combustion automatically. After passing a while, save your result and in the temperature file change your fuel stream temperature to 300 K. This is the way that we start combustion in PaSR model without using ignition.
Regards
Bobi
IColin, Howard and alpercftc like this.
Ignition timing for diesel combustion Ankur Siemens 5 March 15, 2008 21:18
Premixed combustion in Spark Ignition engine kevin FLUENT 1 June 23, 2006 03:59
Ignition and combustion Mai Siemens 7 May 10, 2006 10:59
Spontaneous combustion or auto ignition in FLUENT Seba FLUENT 3 December 9, 2005 00:06
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 19:23
