multiphaseEulerFoam + kineticTheoryProperties |
Paritosh Vasava
Rep Power: 22 ![]() |
Is it possible to use 'kineticTheoryProperties' with multiphaseEulerFoam? Or is the use of 'kineticTheoryProperties' just limited to 'twoPhaseEulerFoam'??
I am simulating flow with two fluids and one solid phase. Although the multiPhaseEulerFoam seem to work fine. I am interested in observing particle-particle and particle-wall interactions especially when particles stick together to form a larger solid body. Please also advise if there is alternate way to do this. |
Paritosh Vasava
anyone has any suggestion?
Paritosh Vasava
I will answer my own question. The 'kinetic theory' is not applicable to multiphaseEulerfoam. I think I will have to look for something else for the particle-fluid type of multiphase model/solver.
Nima
Rep Power: 0 ![]() |
Hi vasava,
Are you able to find a good solver for 2 fluids and 1 solid phase? |
Paritosh Vasava
Hi Nima, No I was not able to solve the problem (with OF2.3).
Since the post there has been newer version of openFoam. I havent had a look at the new OF but you can have a look if the solvers are updated. |
Syavash Asgari
Rep Power: 18 ![]() |
I intend to solve the same system, two fluid with addition of one solid phase (w/o coalescence). What is the best approach for doing this? |
How to tune up interfaceCompression and virtualMass in multiphaseEulerFoam? | petr.f. | OpenFOAM Running, Solving & CFD | 4 | October 28, 2015 05:37 |
query regarding deltaT in multiphaseEulerFoam | bigboss.abhishek | OpenFOAM Running, Solving & CFD | 6 | September 24, 2015 15:56 |
multiphaseEulerFoam | kwardle | OpenFOAM | 3 | March 25, 2013 10:31 |
RASModel in multiphaseEulerFoam | petr.f. | OpenFOAM Running, Solving & CFD | 4 | February 4, 2013 03:01 |
multiphaseEulerFoam loosing fluid with zeroGradient for p on walls??? | petr.f. | OpenFOAM Running, Solving & CFD | 0 | November 28, 2012 06:33 |
