How to input and run a case from earlier version to new version of openFOAM? |
November 19, 2013, 05:12 |
Rep Power: 13 |
I try to run a case of earlier version of openFOAM in openFOAM 2.0.1 but with so many error in running.
for example: the solver cant find the compressible mutWallFunction! and there is no similar valid keywords. |
November 26, 2013, 18:33 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings mamalili,
The standard procedure is to compare the files from 2 similar or identical tutorials between the two versions. Best regards, Bruno
January 30, 2015, 05:03 |
Rep Power: 13 |
tanks a lot my friend
new version, run error |
[snappyHexMesh] OpenFOAM parallel run for Channel Flow | Dmoore | OpenFOAM Meshing & Mesh Conversion | 0 | June 10, 2013 16:08 |
ESI-OpenCFD Releases OpenFOAM v2.2.0 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 13 | March 30, 2013 17:52 |
Same SimpleFOAM Case converges with openFOAM 2.1 but diverges with openFOAM 2.0.1 | alsdia | OpenFOAM Running, Solving & CFD | 3 | October 22, 2012 12:25 |
How can i run case in OpenFOam? | premal | OpenFOAM | 2 | June 24, 2012 01:58 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
