Low-Re k-omega-sst SAS boundary conditions
Like Tree1Likes
  • 1 Post By bmikuz
Old   October 17, 2013, 04:09
Default Low-Re k-omega-sst SAS boundary conditions
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Dear all,
It is hard to find any help about the scale adaptive simulation here or anywhere else.
I am interested in low-Re boundary conditions at walls.
What I did is using the low-Re boundary conditions of the "non-sas" k-omega-sst model for k and omega, thus:
   // k:
   PIPE_WALL
        type          fixedValue;
        value         uniform 1.0e-12;
   // omega:
    PIPE_WALL
        type             omegaWallFunction;
        value            uniform 10000;
k should be set to a very low value >0 and omegaWallFunction can be used, since it is both low-Re an high-Re boundary condition.
Now, what about "nut" and "nusgs"? These values don't have any equation to solve for. So first thing that comes in my mind: Why do they need b.c. at all? Is this something that is needed only for high-Re cases, when the calculated values are overwritten by a wall function?
What I found is, people seem to use "zeroGradient" for "nuSgs" and "zero" or "nutLowReWallFunction" for "nut".
But why not using "calculated" for both nut and nuSgs? They can be calculated, once omega and k are known by their equations. Why would I patch them to something different?
Can anyone help me, I am really stuck with that question!
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   September 26, 2014, 07:33
Blaž Mikuž
bmikuz is on a distinguished road
Hi Phillip,
I see that it has been almost one year since your post here. Did you find out why there is also a b.c. for turbulent viscosity?
This paper could be useful for you:
http://www.tfd.chalmers.se/~lada/pos..._report_WF.pdf
It investigates low-Re and high-Re implementations of b.c. for turbulence models (mostly k-omega).
mj.foamer likes this.
bmikuz is offline   Reply With Quote
Old   September 26, 2014, 08:05
Philipp
I think I found some thesis (also from chalmers?) where it was stated, that the nut b.c. is not used at all and can be set to anything. I will try to find that paper...
k and omega boundary conditions. A.D.E OpenFOAM 8 March 12, 2024 09:55
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 06:35
inlet boundary conditions newOFuser OpenFOAM 1 January 10, 2013 09:08
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
k Omega SST SAS for OpenFOAM 1.5??? barath.ezhilan OpenFOAM Running, Solving & CFD 3 June 2, 2010 08:41
