Getting LinuxMem: [Errno 2] No such file or directory: '/proc/9170/status'
Like Tree1Likes
  • 1 Post By wyldckat
Old   October 2, 2013, 09:51
Default Getting LinuxMem: [Errno 2] No such file or directory: '/proc/9170/status'
s.m
saeideh mohamadi
s.m is on a distinguished road
i am simulating the flow over an airfoil, i use sapalartAllmaras turbulence model, and simpleFoam solver,
after 473 iterate it give me this error and exit the iteration after that :
what should i do, please give me some guidance
Time = 472
smoothSolver:  Solving for Ux, Initial residual = 0.0013927, Final residual = 1.15184e-05, No Iterations 7
smoothSolver:  Solving for Uy, Initial residual = 0.00151985, Final residual = 1.39483e-05, No Iterations 7
GAMG:  Solving for p, Initial residual = 0.0330439, Final residual = 1.83226e-05, No Iterations 10
GAMG:  Solving for p, Initial residual = 0.00158952, Final residual = 1.37841e-06, No Iterations 6
GAMG:  Solving for p, Initial residual = 0.000741389, Final residual = 3.87226e-07, No Iterations 7
time step continuity errors : sum local = 1.82986e-07, global = -1.07452e-14, cumulative = -3.27814e-12
smoothSolver:  Solving for nuTilda, Initial residual = 0.00234781, Final residual = 2.17256e-05, No Iterations 4
--> FOAM Warning :
From function tmp<volScalarField> SpalartAllmaras::k() const
in file SpalartAllmaras/SpalartAllmaras.C at line 243
Turbulence kinetic energy not defined for Spalart-Allmaras model. Returning zero field
--> FOAM Warning :
--> FOAM Warning :
ExecutionTime = 1272.27 s  ClockTime = 1372 s
forceCoeffs output:
Cm    = 0.851865
Cd    = -0.0668863
Cl    = 2.09587
Cl(f) = 1.8998
Cl(r) = 0.196069
forceCoeffs output:
Cm    = -0.0102469
Cd    = -0.0895791
Cl    = 0.207119
Cl(f) = 0.0933124
Cl(r) = 0.113806
forceCoeffs output:
Cm    = 0.32755
Cd    = 0.224488
Cl    = 0.300781
Cl(f) = 0.477941
Cl(r) = -0.17716
Time = 473
Duration of pickling 41.032533884 too long. Extending frequency from 1.0 to 2051.6266942
smoothSolver:  Solving for Ux, Initial residual = 0.00140234, Final residual = 1.15912e-05, No Iterations 7
smoothSolver:  Solving for Uy, Initial residual = 0.00152834, Final residual = 1.40133e-05, No Iterations 7
GAMG:  Solving for p, Initial residual = 0.0337894, Final residual = 1.80586e-05, No Iterations 10
GAMG:  Solving for p, Initial residual = 0.00153707, Final residual = 1.49885e-06, No Iterations 6
GAMG:  Solving for p, Initial residual = 0.000709925, Final residual = 3.63655e-07, No Iterations 7
time step continuity errors : sum local = 1.72361e-07, global = -8.50566e-15, cumulative = -3.28665e-12
smoothSolver:  Solving for nuTilda, Initial residual = 0.00236463, Final residual = 2.18312e-05, No Iterations 4
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
ExecutionTime = 1276.19 s  ClockTime = 1728 s
forceCoeffs output:
Cm    = 0.849925
Cd    = -0.067174
Cl    = 2.09219
Cl(f) = 1.89602
Cl(r) = 0.19617
forceCoeffs output:
Cm    = -0.0101749
Cd    = -0.0889825
Cl    = 0.206383
Cl(f) = 0.0930168
Cl(r) = 0.113367
forceCoeffs output:
Cm    = 0.326995
Cd    = 0.2243
Cl    = 0.300192
Cl(f) = 0.477091
Cl(r) = -0.176899
Time = 474
smoothSolver:  Solving for Ux, Initial residual = 0.00141171, Final residual = 1.16636e-05, No Iterations 7
smoothSolver:  Solving for Uy, Initial residual = 0.00153671, Final residual = 1.40768e-05, No Iterations 7
GAMG:  Solving for p, Initial residual = 0.0348114, Final residual = 3.40433e-05, No Iterations 9
GAMG:  Solving for p, Initial residual = 0.00153878, Final residual = 1.47378e-06, No Iterations 6
GAMG:  Solving for p, Initial residual = 0.000719226, Final residual = 3.64595e-07, No Iterations 7
s.m is offline   Reply With Quote
Old   October 5, 2013, 07:32
Retired Super Moderator
Bruno Santos
Greetings s.m,
A few questions:
  1. Which OpenFOAM version are you using?
  2. Are you able to reproduce this error with one of OpenFOAM's own tutorials?
  3. Which function objects are you using? (It's those inside the block "functions" in the "controlDict" file.)
  4. Can you provide an example case?
  5. Did you run in parallel?
Without this information, my only guess is that the solver crashed in such a way that OpenFOAM's print stack feature didn't work.
Best regards,
Bruno
PS: please follow the instructions on the second link of my signature, for whenever you need to post output from solvers or utilities, or source code!
Old   October 9, 2013, 10:55
s.m
saeideh mohamadi
Originally Posted by wyldckat View Post
Greetings s.m,
A few questions:
Best regards,
Bruno
1. i install "GeekoCFD.x86_64-5.0.0" that is containing the openFoam 2.2.0
2. no i didn't run openFoam's tutorial to get this error
3. i am using the "forceCoeffs" function for expressing the cd&cl on airfoil
4. my case' volume is too large
5. no i didn't run my case in parallel.
i change my opensuse several time, but this problem is still annoying me, and my run stops every 500 steps approximately after giving this error.
Thank you for spending your time to solve my problem
Old   October 11, 2013, 17:25
Bruno Santos
Hi s.m,
My suggestion is to either install OpenFOAM 2.2.1 or 2.2.x, because I've got a feeling that what you are seeing is a bug that has already been fixed in the latest OpenFOAM versions.
If you could adapt an existing OpenFOAM tutorial case to use the same kind of simulation characteristics that your case is using, and if that test case were to give the same error, then you could share that test case and I could confirm if this is a bug in OpenFOAM 2.2.0 that has already been fixed or not.
Either way, from what I can see, there are at least two ways you can install OpenFOAM 2.2.1:
  1. Install GeckoCFD 5.1.0: http://albertopassalacqua.com/?p=1318
  2. Or by following the instructions given here: http://openfoamwiki.net/index.php/In...#openSUSE_12.3
    • Note: For this, you'll have to edit the file "~/.bashrc" and comment out (prepend a # ) the line related to OpenFOAM 2.2 that GeckoCFD provides.
Best regards,
Bruno
s.m likes this.
Old   June 19, 2022, 06:23
Default Getting LinuxMem: [Errno 2] No such file or directory: '/proc/3248/status'
Rakhim
rahim_baatyrov is on a distinguished road
I want to learn how to model Askervane Hill from a model. But I can't repeat it. Gives the following errors:
Create time
--> FOAM Warning :
From function int main(int, char**)
in file reconstructPar.C at line 220
No times selected
/bin/sh: 1: sample: not found
Traceback (most recent call last):
File "./runAskervein.py", line 215, in <module>
plotAskervein.main([target])
File "/home/tim/Downloads/Askervein_template4/plotAskervein.py", line 33, in main
m = max(lastRun)
ValueError: max() arg is an empty sequence
https://openfoamwiki.net/index.php/S...lidation_Cases
(3) Flow over real terrain - Askervein hill (checked on OF 2.1.1)
rahim_baatyrov is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
