EngineFoam OpenFoam v2.2.1
Like Tree1Likes
  • 1 Post By sheaker
Old   September 8, 2013, 17:51
Default EngineFoam OpenFoam v2.2.1
AA29 is on a distinguished road
Hi everyone,
I am trying to use engineFoam (OpenFoam v2.2.1)solver which is basically a RANS solver, for LES modeling. But once i specify the turbulence model as LES, provide LES properties file, and try and run the solver i get the following error :
--> FOAM FATAL ERROR:
request for volScalarField mut from objectRegistry region0 failed
available objects of type volScalarField are
20
thermo:mu
thermosi
b
hau
rho
sqr(((-(0.666667*tr(symm(grad(U))))+sqrt((sqr((0.666667*t r(symm(grad(U)))))+((4*(ce|delta))*(((2*ck)*delta) *(dev(symm(grad(U)))&&symm(grad(U))))))))|(2*(ce|d elta))))
(((2*ck)*delta)*(dev(symm(grad(U)))&&symm(grad(U)) ))
delta
ha
thermosi_0
p
T
Tu
alphaSgs
geometricDelta
(ce|delta)
muSgs
thermo:alpha
ft
From function objectRegistry::lookupObject<Type>(const word&) const
in file /usr/apps1/openfoam-2.2.1/OpenFOAM-2.2.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 164.
Since "mut" is defined for RANS modeling i am confused.Do I need to modify the turbulenceModel.C file in this case?
I tried adding a volScalarfield "mut" to the createFields.H file , just to get things going but i still get the same error.
Please note that I had been switching to LES in version 2.1.1 of the same solver , in the same way without any errors.
Any help will be appreciated.
Thanks in Advance.
AA29 is offline   Reply With Quote
Old   September 8, 2013, 21:06
Post
胡长旭
hcx552362 is on a distinguished road
Originally Posted by AA29 View Post
Hi everyone,
20
thermo:mu
thermosi
b
hau
rho
delta
ha
thermosi_0
p
T
Tu
alphaSgs
geometricDelta
(ce|delta)
muSgs
thermo:alpha
ft
Thanks in Advance.
Hi
I think your 0 files has some question, Maybe you should check it.
good luck
hcx552362 is offline   Reply With Quote
Old   September 28, 2015, 11:27
Amir
infinity is on a distinguished road
hi I've got same problem did you solve the problem
Did you try changing nuSgs to muSgs in source files code?
infinity is offline   Reply With Quote
Old   January 1, 2016, 23:06
Default Try this
Eslam Reda
Eslam Reda is on a distinguished road
I know it's too late to reply but just for future users.
This problem happens due to the misuse of wall functions, try using suitable ones for your model.
Eslam Reda is offline   Reply With Quote
Old   January 2, 2016, 04:57
sheaker's Avatar
Oskar
sheaker is on a distinguished road
I have just run engineFoam for LES turbulence model without errors in openFoam 2.2.1.
Remember that openFoam 2.1.1 is bugged.
1. Copy LESProperties to your constant folder.
2. Change in turbulenceProperties to LESModel.
3. Copy files muSgs and alphaSgs to -180 folder.
3. Change names of boundaryField to piston, liner and cylinderHead (as You call the group of outer faces) in Your files muSgs and alphaSgs.
I haven't done analyse of results yet.
sheaker is offline   Reply With Quote
Old   January 25, 2018, 16:04
savita
renaul4 is on a distinguished road
Hello Oskar,
I'm working on similar application of LES turbulence model in my engineFoam solver in openFoam version 2.4. I'm curious if the above steps lead to correct solution or you made further changes in the solver.
Please advise.
Thanks
renaul4 is offline   Reply With Quote
Old   January 25, 2018, 16:16
sheaker's Avatar
Oskar
Hello.
I just run it. I haven't validate results.
Here is comparison of RANS and LES but no changes for LES settings were made:
https://www.youtube.com/watch?v=HLiJbf95QG4
https://www.youtube.com/watch?v=KA--7CpiCTA
renaul4 likes this.
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 05:48
2009 OpenFOAM Summer School in Zagreb, Croatia hjasak OpenFOAM Announcements from Other Sources 0 March 27, 2009 13:08
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 08:14
