The problem for velocity calculation using turbulent model in openfoam.
Like Tree1Likes
  • 1 Post By haakon
Old   September 4, 2013, 12:18
Default The problem for velocity calculation using turbulent model in openfoam.
Maosong Cheng
mscheng is on a distinguished road
Hi FOAMer,
I use standard k-epsilon model to simulate the velocity of a circular tube(R=1.7m,H=4.0m), but I find the velocity near wall in the inlet become bigger than the velocity fixed in the inlet. what is wrong?
thanks!
mscheng is offline   Reply With Quote
Old   September 9, 2013, 09:10
Maosong Cheng
sorry! the inlet velocity is 0.5m/s.
Old   September 10, 2013, 03:45
haakon will become famous soon enough
I really struggle to get a grip on what the problem really is. Perhaps you could try to reformulate your question/problem? It might as well be good to have some more details.
Perhaps you also could take a closer look on the forum rules? Especially #5 and #8: http://www.cfd-online.com/Forums/misc.php?do=showrules
One last tip: a general idea on how much time you should spend on formulating a question is that you should use as much time formulating your question as you expect people to use on writing answers.
Bernhard likes this.
haakon is offline   Reply With Quote
Old   September 10, 2013, 04:22
immortality's Avatar
Ehsan
immortality is on a distinguished road
what are your BC's?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   September 10, 2013, 04:49
Maosong Cheng
Originally Posted by immortality View Post
what are your BC's?
U BC:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0.5 0);
boundaryField
side
type fixedValue;
value uniform (0 0 0);
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform (0 0.5 0);
k BC:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 3.75E-003;
boundaryField
side
type kqRWallFunction;
value uniform 3.75E-003;
outlet
type zeroGradient;
inlet
type fixedValue;
Epsilon BC:
dimensions [0 2 -3 0 0 0 0];
internalField uniform 1.585453E-004;
boundaryField
side
type epsilonWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 1.585453E-004;
outlet
type zeroGradient;
inlet
type fixedValue;
nut BC:
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
side
type nutWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
outlet
type calculated;
value uniform 0;
inlet
type calculated;
value uniform 0;
p BC:
boundaryField
side
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
inlet
type zeroGradient;
nu = 1.0631e-6
Thanks!
Old   September 10, 2013, 09:24
Ehsan
blue region is wall?
how is grid?
Old   September 10, 2013, 09:35
Maosong Cheng
how is grid?
Hi immortality,
Yes, it is wall.
For the mesh, pls. refer to attached file!
Thanks!
OpenFOAM: LES turbulence model names Ollie OpenFOAM 5 January 7, 2013 11:24
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
simpleFoam: Problem with k-omega Model near Wall okroud OpenFOAM Running, Solving & CFD 0 June 13, 2012 11:13
OpenFOAM: LES turbulence model names Ollie Main CFD Forum 1 April 11, 2011 14:03
Implementing a new LES Model in OpenFoam fs82 OpenFOAM 6 October 13, 2009 10:58
