query regarding deltaT in multiphaseEulerFoam
Like Tree3Likes
  • 1 Post By kwardle
  • 2 Post By kwardle
Old   August 21, 2013, 09:15
Question query regarding deltaT in multiphaseEulerFoam
bigboss.abhishek is on a distinguished road
I am trying to simulate a 3 phase flow by using multiphaseEulerFoam solver. I start with deltaT = 0.001. But during long runs its value decreases. And it is never constant. My second query is that whenever i try to restart the run from t=0 , Openfoam never takes the original deltaT = 0.001 value. I am posting the snippets of my terminal window and control dict file.
Courant Number mean: 0.0570183 max: 0.49767
deltaT = 0.000768923
Time = 0.475434
MULES: Solving for alphawater
water volume fraction, min, max = 0.237401 -1.39992e-09 1
MULES: Solving for alphaoil
oil volume fraction, min, max = 0.331176 -1.28595e-11 1
MULES: Solving for alphaair
air volume fraction, min, max = 0.431422 -2.89095e-11 1
Phase-sum volume fraction, min, max = 1 0.999999 1
water volume fraction, min, max = 0.237401 -3.13086e-09 1
oil volume fraction, min, max = 0.331176 -1.26736e-11 1
air volume fraction, min, max = 0.431422 -2.9056e-11 1
water volume fraction, min, max = 0.237401 -3.0326e-09 1
oil volume fraction, min, max = 0.331176 -1.24904e-11 1
air volume fraction, min, max = 0.431422 -1.09878e-10 1
GAMG: Solving for p, Initial residual = 0.00186816, Final residual = 3.4607e-05, No Iterations 2
time step continuity errors : sum local = 2.95067e-07, global = 1.07225e-10, cumulative = -4.99832e-07
GAMG: Solving for p, Initial residual = 0.00130052, Final residual = 2.03657e-05, No Iterations 2
time step continuity errors : sum local = 1.73768e-07, global = 7.56413e-11, cumulative = -4.99757e-07
GAMGPCG: Solving for p, Initial residual = 0.000449752, Final residual = 3.46072e-08, No Iterations 5
time step continuity errors : sum local = 2.95375e-10, global = 2.05615e-11, cumulative = -4.99736e-07
ExecutionTime = 8560.98 s
i started from deltaT=0.001 but it decreased after some iterations
below is my controldict file
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application multiphaseEulerFoam;
startTime 0;
startFrom latestTime;
stopAt endTime;
endTime 3;
deltaT 0.001;
writeControl adjustableRunTime;
writeInterval 0.2;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 0.5;
maxAlphaCo 0.5;
maxDeltaT 1;
bigboss.abhishek is offline   Reply With Quote
Old   August 21, 2013, 11:37
Kent Wardle
kwardle is on a distinguished road
In this solver and any others of the interFoam family with interfaceSharpening, the time step is by default adapted to maintain the stability criterion of the Co number. In your controlDict you have maxCo = 0.5. and adjustTimeStep = yes. While it is always a good idea to use Co-controlled time step with this type of solver (unless you know exactly what the flow is doing at all times), if you want to keep the time step from changing from your deltaT setting in controlDict, set "adjustTimeStep no;"
Alternatively, depending on how many nAlphaSubCycles you are using (fvSolutions) you could increase the value of maxCo instead to optimize the deltaT and still keep things stable. You want to keep maxCo/nAlphaSubCycles > 0.3.
Hope this helps.
-Kent
BlnPhoenix likes this.
kwardle is offline   Reply With Quote
Old   August 22, 2013, 01:08
Default query regarding deltaT in multiphaseEuler
i changed the controldict as follows
startTime 0;
stopAt endTime;
endTime 3;
deltaT 0.001;
writeControl runTime;
writeInterval 0.2;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
timePrecision 6;
adjustTimeStep no;
maxCo 0.5;
maxAlphaCo 0.5;
maxDeltaT 1;
Its working fine..... ...thanku
Old   August 22, 2013, 01:12
Lightbulb query regarding deltaT in multiphaseEuler
whenever i try to restart the run from t=0 , Openfoam never takes the original deltaT = 0.001 value ??? i am not able to find out why it happened. Although what i do now is that i have made a separate copy of my 0 time directory. whenever i need to take a fresh run i use it and do setFields. I am still not able to figure out the problem. Few people say its a bug.
Old   November 25, 2014, 05:43
herman eselte
hereselte is on a distinguished road
just remove the directory named UNIFORM from that point you will continue.
H
hereselte is offline   Reply With Quote
Old   September 24, 2015, 16:26
Kaufman
kmefun is on a distinguished road
Hi Kent,
For the tutorial (damBreak case) of multiphaseEulerFoam, there is a maxAlphaCo entry in the controlDict which can be used to limit interface Courant number. But, by examining the solver of mpEF (OF-2.4.0 version), I don't see the mpEF implement this function like interFoam. So, I guess that mpEF doesn't take maxAlphaCo into account. and the time step for mpEF is only controlled by maxCo. I would like to make sure whether this is true or not?
Thanks,
Ken
Hope this helps.
-Kent
kmefun is offline   Reply With Quote
Old   September 24, 2015, 16:56
Kent Wardle
This is true. However, the solver is very easily modified to take advantage of the maxAlphaCo. Here are the alphaCourantNo.H and setDeltaT.H files you need to update the solver.
kmefun and Frenk_T like this.
controldict, deltat small, openfoam 2.1.1
how to query node coordinates? phsieh2005 OpenFOAM Post-Processing 3 November 26, 2018 21:13
interDyMFoam deltaT drops non-stop Virtual-iCFD OpenFOAM Running, Solving & CFD 5 June 12, 2015 05:30
multiphaseEulerFoam kwardle OpenFOAM 3 March 25, 2013 11:31
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
deltaT in calculation of time step continuity errors misakagan OpenFOAM Running, Solving & CFD 0 August 27, 2010 11:13
