Pressure drop using Fan type BC
Like Tree1Likes
  • 1 Post By Alexis Sack
Old   August 14, 2013, 08:44
Default Pressure drop using Fan type BC
Alexis Sack
Alexis Sack is on a distinguished road
Hi everyone !
I am new to OpenFoam and I need some help… But first of all I want to thank you all for your job on CFD Online because that already helped me a lot!
I am simulating flow over a car modelled by an Ahmed body using OF 2.2.0. I want to figure out the effect of the cooling system on the drag. So I divided my calculation into 2 parts:
1. Calculation of the pressure drop due to the cooling system: I got the pressure drop over inlet velocity curve.
2. Calculation of the flow over the Ahmed body including my negative pressure drop boundary condition: I am using a Fan BC with a csv file to define the pressure drop curve.
My meshing software is HyperMesh (Altair software).
Here is my problem: when I simulate a 3 million cells mesh, I get a correct pressure drop, but if I simulate an over 4 million cells mesh, I get a pressure rise instead of a drop. The weird fact is that my files are exactly the same, only the mesh is changing.
Does anybody have an idea of what happens in my calculations?
Thanks in advance!
Alexis
Alexis Sack is offline   Reply With Quote
Old   September 1, 2013, 05:45
Default Pressure drop problem: solution
Alexis Sack
Ok I found the solution this past week!
I am posting it because I guess it may help someone one day, that is a little bit tricky.
So my problem came from parallel processing: if you are using cyclic type boundary conditions and parallel processing, you have to make sure 2 matching faces are in the same processor, otherwise you won't get proper results!
For that purpose, just change your decomposition direction and that should work good
coroi likes this.
Old   September 22, 2014, 10:18
coroi is on a distinguished road
Thank you very much for this post!! It was very helpful to me!
coroi is offline   Reply With Quote
fan bc, mesh problem, pressure drop
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
inlet pressure is higher than outlet pressure for fan sivakumar OpenFOAM Pre-Processing 16 December 30, 2017 15:16
T Junction Stability ignacio OpenFOAM Running, Solving & CFD 5 May 2, 2013 11:44
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 18:18
