how should we difine the CofR in forceCoeffs function,to get right resut for "cm"??
Like Tree2Likes
  • 1 Post By s.m
  • 1 Post By immortality
Old   August 11, 2013, 06:32
Default how should we difine the CofR in forceCoeffs function,to get right resut for "cm"??
s.m
saeideh mohamadi
s.m is on a distinguished road
Hi all,
as you know in the path "/opt/OpenFOAM/OpenFOAM-2.2.x/tutorials/incompressible/pimpleDyMFoam/wingMotion"
there is an example for analyzing the flow over an airfoil, in it's controlDict you can find a function that is defined to give force on the airfoil, we also have similar function to give us the force Coefficient.
functions
forces
type forces;
functionObjectLibs ( "libforces.so" );
outputControl timeStep;
outputInterval 10;
patches (wing);
pName p;
UName U;
rhoName rhoInf;
log true;
rhoInf 1;
CofR (0.4974612746 -0.01671895744 0.125);
my Question is about "Cof R"
what CofR is?
how should we intruduce it ? as you see, it doen't write cofR (0 0 0) , hoe these values "0.4974612746" & "-0.01671895744" & "0.125" compute?
immortality likes this.
s.m is offline   Reply With Quote
Old   August 11, 2013, 18:40
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi Saeideh
Its only "center of rotation"
Select aerodynamic center or where you know by your reference.
How did you resolved the problem of resonance of Cl and Cd diagrams(that coeffs in slat were not so good)?
s.m likes this.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   August 12, 2013, 07:09
s.m
saeideh mohamadi
Originally Posted by immortality View Post
hi Saeideh
Thanks Ehsan,
would you please tell me what is A, B, C in CofR (A,B,C) is?
i read that in subsonic airfoil, ayrodynamic center is located in c/4, but in abbott's book that i want valid my results, there is two figure for moment coeifficient of naca 4412 at Re=3*10e6 ; 1-for c/4 and 2- for ayrodynamic center.
if we have the coordinate for ayrodynamic center, e.g a.c =( x=0.2, y =-0.6)
we should write them in cofR in this way: cofR = (x=0.2, y=-0.6, 0)?
Old   August 12, 2013, 08:11
Ehsan
Hi Saeideh
yes I've seen those figures.I can't remember the reason but can ask for you.
yes I think it should be written as you said.test it and let me know.
Old   August 14, 2013, 06:22
s.m
saeideh mohamadi
Hi Saeideh
Hi,Ehsan
Thank you very much
actually i get a better result for cm by setting the " CofR(0.72 0 0) // Axle midpoint on ground" than setting the cofR(0.245 -0.068 0) for NACA 4412.
for first setting cm= -0.09
for second one cm= 0.1
Old   October 9, 2019, 00:33
moweijie
mowei is on a distinguished road
Hi, everyone!
I want to ask a question about Cof, if the wing moves up and down, how should I set the Cof, still keep a fixed value? Can anyone help me solve the question?
mowei is offline   Reply With Quote
