Low Reynolds number question
Like Tree4Likes
  • 4 Post By kalle
Old   August 10, 2013, 11:49
Default Low Reynolds number question
wildfire230 is on a distinguished road
Does anyone know why using small Reynolds numbers ( < 5 ) requires continuously smaller time steps? Even with the cavity tutorial, using Reynolds numbers less than one requires very small time steps to prevent the Courant number from exploding. There is probably something fundamental I'm missing. Is icoFoam not the best choice for low Reynolds numbers?
Thanks for your help.
wildfire230 is offline   Reply With Quote
Old   August 10, 2013, 14:13
Glenn Carlson, PE, PhD (ret)
gcengineer is on a distinguished road
Sorry. I'm not sure what you mean by "small Reynolds numbers."
Do you mean the velocity of the wall is low? Or are you referring to the behavior of turbulence models close to a wall?
Of course, very fine meshes can require small time steps to avoid large Courant numbers, but it doesn't sound like this is what you are referring to.
gcengineer is offline   Reply With Quote
Old   August 10, 2013, 14:20
Hi, thanks for you reply. I mean Reynolds numbers less than 5. I run into this problem with every mesh while using icoFoam, even the cavity tutorial. For example, in the cavity tutorial, the only thing I am changing is the Reynolds number, not the grid size or the velocity. I am controlling the Reynolds number by changing the kinematic viscosity. As far as I am aware, you only need to decrease the time step if you decrease the grid size in the direction of the velocity, or increase the velocity in the direction of the grid. However, when I start decreasing the Reynolds number below 5 or below 1, etc... I have to significantly decrease the time step in order to preserve stability.
Old   August 10, 2013, 14:57
Sorry again.
How are you calculating Reynolds number? Re = UD/nu, where U is velocity of moving wall and nu is kinematic viscosity? What are you using for D? The length of a side of the cavity? Something else?
Are you modeling turbulence? If so, what model are you using?
Also, what version of OpenFOAM are you using?
Old   August 10, 2013, 15:25
I'm calculating the Reynolds number as you said, Re = U * d / nu, where U = 1, d = 0.1. Thus my Re = 0.1 / nu. Just as they do in the cavity tutorial. I'm not modelling turbulence, as icoFoam is a laminar solver, and I'm using OpenFOAM 2.2.0. Everything is fine for Reynolds numbers from say 5 to 100, but with Reynolds numbers less than 5 or 1, I have to decrease the time step to preserve stability. I should also note that I am not using implicit schemes.
Old   December 12, 2013, 10:47
Otto S.
Otto S. is on a distinguished road
Dear wildfire230,
I have a similar problem: With increasing viscosity I have to lower the time steps. Do you found a solution for this problem?
Otto S. is offline   Reply With Quote
Old   December 13, 2013, 02:55
Karl-Johan Nogenmyr
kalle is on a distinguished road
Ferziger and Peric discusses this. In 2nd edition you'll find it in section 6.3.1. When diffusion starts to dominate over convection, you have another instability to cater for than the one set by the Courant number. You'll trigger the instability by refining mesh, or increasing viscosity. And if your solver only sets time step according to Courant number, you'll trigger it when the Courant number allows you to take large time steps.
deltaT < 1 / ( 2*Gamma/(rho*dx*dx) + u/dx )
Courant number is only the last term above. (Gamma is diffusion coefficient (viscosity))
tfuwa, lev, SHUBHAM9595 and 1 others like this.
kalle is offline   Reply With Quote
Old   December 13, 2013, 05:34
Otto S.
Hey kalle,
thank you for your answer! This is the explanation I was looking for.
plotting drag coefficient in low reynolds number flow past cylinder atmcfd FLUENT 0 January 2, 2010 09:34
low reynolds number K-epsilon model amar STAR-CD 2 March 23, 2009 08:24
Low Reynolds number airfoil. Pablo Cornejo FLUENT 14 October 19, 2005 10:41
DNS -low Reynolds number Airfoils Pat Main CFD Forum 2 January 21, 2005 15:17
Low Reynolds number for airfoil Richard Main CFD Forum 1 March 20, 2000 08:24
