Strange Result of ERCOFTAC Centrifugal Pump MRF case in OF2.2.x
Like Tree1Likes
  • 1 Post By linnemann
Old   August 7, 2013, 21:03
Default Strange Result of ERCOFTAC Centrifugal Pump MRF case in OF2.2.x
Masashi Ohbuchi
Ohbuchi is on a distinguished road
Recently, I've tried ERCOFTAC Centrifugal Pump MRF case (ECPGgi2D) for OpenFOAM-2.2.x, and encountered strange results as attached images.
For comparison, I've also attached the results for OF2.1.x.
Results for OF2.1.x are in good agreement with original published results (OF-1.5-dev).
For OF2.2.x case, I used simpleFoam with following fvOptions.
-------fvOptions ----------------------------------------------------
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvOptions;
MRF1
type MRFSource;
active true;
selectionMode cellZone;
cellZone rotor;
nonRotatingPatchs ( INLET OUTLET GGI_EXT GGI_INT BLADE_ROT);
MRFSourceCoeffs
origin (0 0 0);
axis (0 0 -1);
omega 209;
If someone has the solution to correct this problem, please let me know.
Any comment would be appreciated.
Ohbuchi is offline   Reply With Quote
Old   August 12, 2013, 06:17
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
I have no problems with commit 2.2.x-b6d83360ae0e
I have uploaded the working case here and removed the reliance on the old turbo stuff. Only 2.2 BC's.
LINK TO CASE
Ohbuchi likes this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   August 12, 2013, 20:48
Masashi Ohbuchi
Hi, linnemann.
I tried case file of you, I was able to get same result as you.
But for now, I could not find any important difference in your dictionary files with mine.
I'm going to continue to investigate in detail.
Best regards,
Masashi Ohbuchi
Old   September 10, 2013, 05:18
Brahim Aakti
brahim is on a distinguished road
here some comments on your fvOptions:
- there is a typo in the nonRotatingPatchs -> nonRotatingPatches
- I would not declare the patch BLADE_ROT as non-rotating
Here is the fvOptions I'm using:
MRF1
    type            MRFSource;
    active          true;
    cellZone        rotor;
    MRFSourceCoeffs
        nonRotatingPatches (INLET OUTLET GGI_EXT GGI_INT);
        origin      (0 0 0);
        axis        (0 0 -1);
        omega       209;
Best Regards - Brahim.
brahim is offline   Reply With Quote
Old   December 6, 2013, 06:14
nash is on a distinguished road
hi everyone,
are the nonRotatingPatches needed to be included in the dict?
in my case (3D radial fan) the mrfZone is a cylinder and within the cylinder there are wall (from the fan blade)
so should i add the wall within the mrfZone in the nonRotatingPatches or just leave it without nonRotatingPatches?
thanks
regards,
nash
nash is offline   Reply With Quote
Old   December 6, 2013, 10:20
i have tried without including the patch and with the patch included in fvOption.
the right one is not to include the patch within the mrfZone as nonRotatingPatches.
Hope this helps.
regards,
nash
Old   December 13, 2013, 04:48
Default Help
Minh-VietNam
mingbn is on a distinguished road
Originally Posted by linnemann View Post
Hi
LINK TO CASE
Hi
I'm a new openfoam user. I am interested in your case. (i'm studying about centrifugal pump). I tried your case but i can't get results the same your.
(i'm using ubuntu 13.04; openfoam 2.2.2)
Please show to me.
Thank you so much.
File Type: jpg Screenshot from 2013-12-13 15:44:06.jpg (46.9 KB, 33 views)
File Type: jpg Screenshot from 2013-12-13 15:45:15.jpg (45.8 KB, 27 views)
mingbn is offline   Reply With Quote
Old   January 15, 2014, 23:46
Default ercoftac Centrifugal Pump for OF2.2.x
Masashi Ohbuchi
Thank you, Brahim.
And I appologize for my delayed response.
You were correct!.
My essential mistake was the setting of nonrotatingPaches.
I've attached case files adapted to OF2.2.x.
All validation cases; ECPGgi2D(MRF+Ggi), ECPStitchedMesh2D(MRF+StitchMesh)
and ECPMixerGgiFvMesh2D(Sliding+Ggi) will be working fine.
The Allrun script in the postProcessing directory also works.
In these archive, because of the limitation of maximum size, mesh files(rotor2D and stator2D) and measurement data are not included.
Best regards,
M.Ohbuchi
Old   April 30, 2015, 06:03
M. Montero
be_inspired is on a distinguished road
Thank you for adapting the case to OF2.2.x. I am trying to use OF2.3.x for my case but with some problems.
I have some doubts:
It seems like now it is not needed to make faceZones. It is enough with cellZone definition performed inside topoSet. And now, inside OF code faceZone selection is done automatically.
Ohbuchi has defined BLADE_ROT within patches subDict. I thought that is not needed because by default all patches included in the MRF zone were rotated.
I am trying to simulate a rotor with a fixed part of the geometry but there are problem in the rotor surface. k, epsilon and so give very extrange values ( +12 or so at iteration 5).
For nonRotatingPatches I have added only AMI1 and AMI2 interfaces.
Mesh was generated for y+ around 100 so I am using nutkWallFunction.
I hope someone can help me.
be_inspired is offline   Reply With Quote
Old   May 3, 2015, 06:01
Masashi Ohbuchi
HI,
Please check and see attached tar archive. It'll work with OF2.3.
As you already mentioned above, cellZone is only needed for defininig MRF zone.
And faceZone was not used in my case files.
And I also think nutkWallFunction is more suitable for wall boundary for k.
Ohbuchi
Originally Posted by be_inspired View Post
I have some doubts:
Old   May 10, 2015, 04:47
Huang Xianbei
huangxianbei is on a distinguished road
Hi
LINK TO CASE
Dear Niels Nielsen:
Thank you for your sharing. But I can't open the link, could you please send a copy to my email znhuang@163.com?
Xianbei
huangxianbei is offline   Reply With Quote
release of the ERCOFTAC centrifugal pump - Fourth OpenFOAM Workshop olivier OpenFOAM 8 October 29, 2018 08:49
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
strange behaviour of GGI in parallel on axis symmetrical case A.Devesa OpenFOAM Running, Solving & CFD 0 April 6, 2010 04:58
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
centrifugal pump john Main CFD Forum 0 April 22, 2004 07:13
