what should i do to have more accurate results for analysing the flow over a airfoil? |
August 4, 2013, 05:40 |
saeideh mohamadi
Rep Power: 15 |
Hi, i want to have a more lower residual for my analysis, what should i do?
i also want to have a more accurate results, on slat pressure coeffient, what changes should i do in my setting of openfoam? i attach the experiment pressure coefficient result and the pressure coefficient that is resulted from my simulation in the next thread. as you see i don't have an accurate result for my slat, what should i do? |
August 4, 2013, 05:52 |
saeideh mohamadi
Rep Power: 15 |
these are the experiment and my simulation result for pressure coefficient of slat and flap elements.
as you see i don't have accurate result for slat, and whan i change the turbulence model from kw-sst to RNGkEpsilon it become more inaccurate, why? |
August 4, 2013, 05:58 |
saeideh mohamadi
Rep Power: 15 |
these are the experiment and my simulation result for pressure coefficient of main element.
as you see in 0 folder, i use freestream boundary condition for my simulation, this boundary give me more better result than the velocity inlet&pressure outlet. |
August 4, 2013, 11:11 |
#4 | |
Nima Samkhaniani
Rep Power: 25 |
change in fvSolution for atleast U and p to
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
August 5, 2013, 06:17 |
saeideh mohamadi
Rep Power: 15 |
Ok Dear nima, would you please explain the differences between tolerance and reTol in fvSolution ?
Thank you as you see the reduction of my residuals are really low, especially for p, i'll do what you said, and attach the residual figure. |
August 5, 2013, 06:40 |
Nima Samkhaniani
Rep Power: 25 |
well
relTol is relative tolerance and tolerance is absolute one so it would be clear why relTol should be 0.0
Airfoil conditions for unsteady flow | Dave | Main CFD Forum | 3 | April 24, 2008 18:11 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 08:40 |
Simulating flow past airfoil with different AOA | Quarkz | Main CFD Forum | 2 | January 6, 2006 11:56 |
How accurate are non-convergent results? | Chris | FLUENT | 12 | April 21, 2005 04:56 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
