Can I use simpleFOAM as a transient solver ?!
Like Tree2Likes
  • 2 Post By Lieven
Old   August 2, 2013, 02:42
Default Can I use simpleFOAM as a transient solver ?!
Amin
Mirage12 is on a distinguished road
I would like to use SIMPLE algorithm for transit simulation.
My problem : I could not use IcoFoam oder PiscoFoam..because the the solvers are crashing. (the mesh could be the reason).
So i thought, i run a simulation as a steady case ( to stabilyse the case ) using simpleFoam, after some seconds, i want to run the simulation as transient case..
Normally for the steady-case, we use :
ddtSchemes
    default         steadyState;
Can i change the dttSchemes :
ddtSchemes
    default         Euler;
to change my simulation from steady to transient after some seconds?
Thank you
Mirage12 is offline   Reply With Quote
Old   August 2, 2013, 03:00
Lieven
Lieven will become famous soon enough
Changing the ddtSchemes-entry wouldn't affect your simulation at all. The momentum equation in the simpleFoam solver does not include the time derivative so the ddtSchems-entry is even not used.
In principle you could add the time derivative to the equation, but with the simple algorithm you will always be stuck with under relaxation. So you cannot do proper time integration. So use the piso algorithm for transient simulations.
Cheers,
L
kiddmax and reverseila like this.
Lieven is offline   Reply With Quote
Old   August 2, 2013, 08:24
Amin
Thanks Lieven
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
time step and iterations in steady state problem using transient solver jing113cn FLUENT 2 January 15, 2010 04:18
inlet boundary condition for simplefoam solver mcjicpm2 OpenFOAM Running, Solving & CFD 1 March 18, 2009 01:41
Steadystate versus Transient solver pda OpenFOAM Running, Solving & CFD 1 July 11, 2007 09:36
Transient UDS with coupled solver Dmitriy Makarov FLUENT 1 February 9, 2007 18:06
