mastering fvSchemes in OpenFOAM
Like Tree8Likes
  • 3 Post By Lieven
  • 1 Post By immortality
  • 2 Post By Lieven
  • 1 Post By Pat84
  • 1 Post By Tushar@cfd
Old   July 20, 2013, 09:12
Default mastering fvSchemes in OpenFOAM
Zifei Yin
yzf1215 is on a distinguished road
Its easy to use Gauss upwind and Gauss linear in OpenFOAM with good robutness. However, when I used other fvSchemes like MUSCL, Fourth etc. It often turns out to be EOF error.
I'd like to know the reason behind it and the way to master using fvSchemes in OpenFOAM.
Many thanks!
yzf1215 is offline   Reply With Quote
Old   July 20, 2013, 10:48
Lieven
Lieven will become famous soon enough
Hi yzf1215,
Several of the schemes you can select in the fvSchemes-file require a number of arguments (either floats or words). When you get an EOF error it could indicate that you didn't provide them.
Cheers,
Lieven
Lieven is offline   Reply With Quote
Old   August 9, 2013, 16:06
s.m
saeideh mohamadi
s.m is on a distinguished road
Originally Posted by Lieven View Post
Hi yzf1215,
Cheers,
Lieven
Hi lieven
how should we provide them for removing this error,
when i change the Guass Upwind for "di(phi ,omega)" to Guass linearupwind i also get this error,
i thank you if you explain it more
s.m is offline   Reply With Quote
Old   August 9, 2013, 16:40
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
set it to Gauss linearUpwind phi; for example.or Gauss linearUpwind grad(omega);
and then define grad(Omega) in grad dictionary.both of these terms indicate the direction of flow(that divergence should act at that direction) for solver.hope be solved by this.
s.m likes this.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Lieven
Have a look at http://www.openfoam.org/docs/user/fvSchemes.php
there you have a few examples given...
Cheers,
L
s.m and Annier like this.
Old   August 9, 2013, 17:10
s.m
saeideh mohamadi
i get it dear lieven & dera ehsan
thank you
Old   August 11, 2013, 05:29
s.m
saeideh mohamadi
Originally Posted by immortality View Post
Hi
Dear Ehsan,
are thease two divergence schems the same? "Gauss linearUpwind phi" & "Gauss linearUpwind grad(omega)"
if yes, phi means grad(omega)?
is it true to write Gauss linearUpwind grad(U) instead of Gauss linearUpwind grad(omega)?
Old   August 11, 2013, 05:38
Ehsan
no they are different by themselves but "here" they have the same role of showing direction to the solver.
for Omega you better use grad(Omega) and for U,grad(U) for more clarification.but both show direction of flow for calculation of terms.
Old   August 11, 2013, 05:47
s.m
saeideh mohamadi
i can understand that what is the grad(omega) is, but i can understand what is the phi?
Old   August 11, 2013, 05:51
Patrick Wollny
Pat84 is on a distinguished road
Since linear upwind has the additional term r.grad(omega) in the case of div(omega), I would prefer grad(omega).
s.m likes this.
Pat84 is offline   Reply With Quote
Old   December 4, 2014, 10:34
Default fv-schemes
  #11
Tobias Adam
Tobias Adam is on a distinguished road
Hey everyone
I try to find an explantation to the fv-schemes.
I know how to use the main schemes. But I like to understand all schemes from this list.
Does anyone know where to find information about these.
Information could be anything like, the mathematical explanation the fv-schemes ( still I don´t understand c++) or descriptions about when to use which scheme.
The schemes I want to know about are listed in this document:
https://docs.google.com/document/d/1...it?usp=sharing
Tomorrow I´m going to ask someone to help me with C++, but I would be happy for each kind of information :-)
Best regards Tobi
Tobias Adam is offline   Reply With Quote
Old   December 5, 2014, 04:23
T. Chourushi
Tushar@cfd is on a distinguished road
Hello Tobi Adam,
I guess there was discussion on the forum sometime back. I think you should have a look to the post referred below.
http://www.cfd-online.com/Forums/ope...tml#post348575
Best Luck!
Tobias Adam likes this.
Tushar@cfd is offline   Reply With Quote
Old   January 30, 2017, 06:49
muhammet çevik
muhmt.cvk is on a distinguished road
hi Tobias
I am also trying to find an explantation to the fv-schemes. Did you find something useful. If you ,Could you share for me
Best
muhmt.cvk is offline   Reply With Quote
eof, fvschemes, openfoam
ESI-OpenCFD Releases OpenFOAM v2.2.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 13 March 30, 2013 17:52
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 05:48
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 08:14
