Code for EARSM by Hellsten and RSM by Manceau, square duct, 2d turbulent channel
Like Tree10Likes
  • 3 Post By Thomas Baumann
  • 3 Post By Ardali
  • 2 Post By Thomas Baumann
  • 2 Post By aguademarco
Old   July 18, 2013, 08:39
Default Code for EARSM by Hellsten and RSM by Manceau, square duct, 2d turbulent channel
Thomas Baumann is on a distinguished road
Hi everybody,
under the link
http://www.istm.kit.edu/english/83.php
you can download some codes and tutorials of turbulence models I implemented in OpenFOAM for different versions. They are implemented for incompressible flow (simpleFoam, pisoFoam,...). I validated them at serveral cases (2d channel, square duct, annular pipe flow, rod bundles).
OpenFOAM 1.7.0
Code: nonlinear algebraic stress model ( EARSM ) by Hellsten and two validationcases: channel flow and square duct. Good agreement of the velocity profile at the 2d channel. The uv Reynolds stress is good (even for a annular pipe flow). (uu, vv, ww) are too low.
Pic: EARSM_2dchannel_Reynolds_stresses.jpg
OpenFOAM 2.1.0
Code: Reynolds stress model ( RSM ) by Manceau and the same two validation cases. Good agreement of velocity profiles, Reynolds stresses and secondary flows (see the pics)
PICS:
RSM: Reynolds stress profiles of a 2d channel
RSM: Square Duct
Post-Processing yplus: To check the y+ values: post-processing tool to calculate them using low Reynolds models.
Good luck
Thomas
hswzzz, Aaron_L and lpz456 like this.
Thomas Baumann is offline   Reply With Quote
Old   October 16, 2013, 21:04
alexander_s is on a distinguished road
Hello Thomas,
thank you very much for providing your files!
I am interested in your square duct simulation using the Reynolds-stress model you implemented. Unfortunately, the link to the case setup (OF211_RSM_Manceau_quadchannel) doesn't work correctly (it's linked to the EARSM case). I wonder if you could fix it or upload your case folder here, since I have some problems with setting the right boundary conditions / fvSchemes.
Thank you in advance!
Alex
alexander_s is offline   Reply With Quote
Old   October 23, 2013, 12:43
I have uploaded it now.
Try following link:
https://dl.dropboxusercontent.com/u/...channel.tar.gz
Regards Thomas
Old   October 29, 2013, 21:15
Hello Thomas,
thank you very much for your reply. Could you also upload the 3D case of a square duct (OF211_RSM_Manceau_quadchannel) or do you use the same boundary conditions and fvSchemes as for the 2D channel?
Furthermore, I have some questions concerning the 2D case you've just uploaded.
What kind of boundary condition do you use for epsilon? Do you calculate the values for epsilon a priori and impose them as fixedValue?
Is the initialization of the flow field important?
If I get it right, there is no need for any lowReWallfunctions when using your code?
Best wishes,
Alex
Old   October 29, 2013, 23:10
here is the correct link for the quad-channel.
It is a low Reynolds-number model with a elliptic factor, no damping functions are necessary... epsilon is calculated by a correction-function within the code. Its put to fixed value, but every time step the boundary values are updated.
I made pre-simulations with the Launder-Sharma-model and used the results as starting conditions, because of the model is very sensitive.
Of course, you have to correct the boundary conditions.
You must read the papers of Manceau to understand the code. (an improved version ....)
Best regards,
Thomas
Old   October 31, 2013, 12:52
Hi Thomas,
thank you once again. You helped me a lot!
Alex
Old   February 17, 2014, 04:34
Blaž Mikuž
bmikuz is on a distinguished road
Hi Thomas,
I've tried your quadchannel case and it works fine if I run it on a single core. Since I'd like to test it also on a bigger case I'll need to run it in parallel. The problem is that the case cannot be decomposed and it returns me the following error:
HTML Code:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : decomposePar
Date   : Feb 17 2014
Time   : 09:29:22
Host   : "krn"
PID    : 31017
Case   : /home/r4/mikuz/MATIS-H/MATiS-bmk/steady/Mine_Fine_mesh/Baumann/quadchannel_paral
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
--> FOAM Warning :
    From function dlOpen(const fileName&, const bool)
    in file POSIX.C at line 1175
    dlopen error : /home/r4/mikuz/OpenFOAM/mikuz-2.1.1/platforms/linux64GccDPOpt/lib/libRSMEBMenhanced.so: undefined symbol: _ZN4Foam14incompressible8RASModel11printCoeffsEv
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName&, const bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 96
    could not load "/home/r4/mikuz/OpenFOAM/mikuz-2.1.1/platforms/linux64GccDPOpt/lib/libRSMEBMenhanced.so"
Create mesh
Calculating distribution of cells
Selecting decompositionMethod simple
Finished decomposition in 0.29 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
--> FOAM Warning :
--> FOAM Warning :
Processor 0
    Number of cells = 63000
    Number of faces shared with processor 1 = 3718
    Number of processor patches = 1
    Number of processor faces = 3718
    Number of boundary faces = 7800
--> FOAM Warning :
--> FOAM Warning :
Processor 1
    Number of faces shared with processor 0 = 3718
    Number of faces shared with processor 2 = 3600
    Number of processor patches = 2
    Number of processor faces = 7318
    Number of boundary faces = 4200
--> FOAM Warning :
--> FOAM Warning :
Processor 2
    Number of faces shared with processor 1 = 3600
    Number of faces shared with processor 3 = 3718
--> FOAM Warning :
--> FOAM Warning :
Processor 3
    Number of faces shared with processor 2 = 3718
Number of processor faces = 11036
Max number of cells = 63000 (0% above average 63000)
Max number of processor patches = 2 (33.3333% above average 1.5)
Max number of faces between processors = 7318 (32.6205% above average 5518)
Time = 0
Processor 0: field transfer
--> FOAM Warning :
--> FOAM Warning :
Processor 1: field transfer
--> FOAM Warning :
--> FOAM Warning :
Processor 2: field transfer
--> FOAM Warning :
--> FOAM Warning :
Processor 3: field transfer
--> FOAM Warning :
--> FOAM Warning :
End.
Do you have the same problem?
Thanks!
Blaz
bmikuz is offline   Reply With Quote
Old   March 3, 2014, 15:52
Mohammadreza Abyanaki
mra-cfd is on a distinguished road
Dear Thomas,
Would you please write down exact reference to works of Manceau and Hellsten? I am not sure about title of the papers.
Regards,
Mohammadreza
mra-cfd is offline   Reply With Quote
Old   August 4, 2014, 16:23
Default Expressing the production term 'G'
Manan
MaLa is on a distinguished road
Hi Thomas
Thanks for the code!
MaLa is offline   Reply With Quote
Old   November 27, 2014, 16:31
Shahr is on a distinguished road
Thanks for sharing your code and the results.
Has anybody managed to compile the EARSM code for newer openfoam versions?
I have been struggling with it for some time without any success.
Shahr is offline   Reply With Quote
Old   January 18, 2015, 16:12
Here are some infos; bit late
the EARSM from Hellsten is the version from his Dissertation:
new two equation turbulence model for aerodynamics applications.
The RSM by Manceau should be the one from the paper:
AN IMPROVED VERSION OF THE ELLIPTIC BLENDING MODEL
APPLICATION TO NON-ROTATING AND ROTATING CHANNEL FLOWS
Old   April 10, 2015, 09:56
Ardalan
Ardali is on a distinguished road
I'm working with Remi Manceau now, your code is helpful a lot
A note:
The current version of the code is not robust.
You need to make it stable.
Split the anisotoropy tensor to deviatic and diagonal and use Sp in deviatic part! check the implementation of Spezial-Sarkar-Gatski RSM as well.
This is my REq:
tmp<fvSymmTensorMatrix> REqn
fvm::ddt(R_)
+ fvm::div(phi_, R_)
//+ fvm::SuSp(-fvc::div(phi_), R_)
- fvm::Sp(fvc::div(phi_), R_)
- fvm::laplacian(nu(), R_)
- fvm::laplacian(CMu/sigmak*TEBM*R_,R_) //anisotrope SSG-Modellierung
+ fvm::Sp(anisotrope, R_)
P
- fvm::Sp(epsilonterm1, R_)
+isotrope
-epsilonterm2
+phistar
If you have problem with it contact me!
Ardalan Javadi
abe, purnp2 and lpz456 like this.
Ardali is offline   Reply With Quote
Old   April 4, 2019, 01:02
Default request to re-upload the code
  #13
Purn Prakash
purnp2 is on a distinguished road
Sir Baumann,
none of the links is working in the present time (2019) so if you are still active, please update the link.
Thank you for your time.
purnp2 is offline   Reply With Quote
Old   July 10, 2020, 10:40
Default code for the RSM by Manceau und the EARSM by Hellsten
  #14
Hallo, the former links don't work anymore.
Here is the code for the RSM by Manceau und the EARSM by Hellsten.
Its the OF 1.7 and the OpenFOAM 2.11 Version.
dradenkovic and lpz456 like this.
Old   October 16, 2020, 05:11
aguademarco is on a distinguished road
Dear Thomas Baumann,
thanks for the codes that you shared. Now I am trying to converting your RSTM Elliptic Blending model in OpenFoam 6: I did only minor syntax changes to your version and then I compiled it successfully. I tried then to reproduce your results for the channel flow at Re_tau=395, but I got very different results with poor accuracy. Could you please share again also the channel test case that you used for the validation?
Thank you very much in advance
Matilde
lpz456 and tyskies like this.
aguademarco is offline   Reply With Quote
