Solver for Curved Channel
Like Tree2Likes
  • 1 Post By saadat66
Old   July 17, 2013, 01:24
Default Solver for Curved Channel
Mohammad
mohammad81 is on a distinguished road
Dear Foamer,
I want to model 2D laminar incompressible flow in a curved channel (a finite length of a channel), say something like cavity problem, except that the bottom and top walls are curved and fixed walls (the driving force is the pressure gradient).
I want to use cyclic boundary conditions for the problem.
Do you know what solver shall I use? icoFoam, simpleFoam, pimpleFoam, etc.
(A solver that can handle cyclic BC.)
I know channelFoam was a good one, but it is removed in OF 2.2.1 and my flow is laminar.
Thank you so much.
Mohammad
mohammad81 is offline   Reply With Quote
Old   July 17, 2013, 03:29
Steven
Darth2013 is on a distinguished road
I also have a similar problem.
Anybody has an idea?
Thanks.
Steven
Darth2013 is offline   Reply With Quote
Old   July 17, 2013, 10:42
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Should be easy. Get back the channelFoam or do some combination with simpleFoam algorithm in case you want to do a steady RANS.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   July 17, 2013, 11:09
Steven
Hi Daniel,
Thanks for the reply.
I do not need RANS, since my flow is laminar.
1. But I do not understand your comment of getting back to ChannelFoam?!
2. Shall I also add a pressure gradient to the code? (since the driving force is pressure gradient) and if yes how?
3. I used cyclic BC for U and Fan BC for P. Do you think this is correct? I mean does this Fan BC creates a kind of pressure gradient pr I have to do something else?
Thanks so much.
Mohammad
Old   August 1, 2013, 17:38
Mohammad
saadat66 is on a distinguished road
Dear mohammad81,
you can use ChannelFoam solver to simulate laminar flow in finite pipe. you should use channelFoam toturial test case and simply change LESModel in (your case directory/constant/LESProperties) from SGS model to "laminar". then run channelFoam command to run your case. but you see error messages and your run don't start. to overcome these errors you should add approprate divergence schemes to fvSchemes file(simply change nuEff to nu and etc).
I hope this help you.
Darth2013 likes this.
saadat66 is offline   Reply With Quote
Old   August 1, 2013, 17:54
Mohammad
Dear Darth2013
if you use channelFoam solver to simulate your laminar test case with approprate modifications from previous post, you don't need to know any pressure gradient and also no need to change the main code. but you should know mean velocity in your test case (pipe, channel and etc). and simply add this parameter in transportProperties such as below:
Ubar Ubar [ 0 1 -1 0 0 0 0 ] ( 15.631 0 0 );
channelFoam solver calculate pressure gradient at every time step and write it in time directory.
Mohammad
Old   June 1, 2014, 12:02
Niu
Z.Q. Niu is on a distinguished road
Dear Mohammad,
Is Ubar the mean velocity at the inlet ?
Z.Q. Niu is offline   Reply With Quote
Old   June 1, 2014, 15:38
Mohammad
Dear Z.Q. Niu,
yes, Ubar is the mean velocity that you can calculate it from bulk Reynolds number (Re=H*Ub/nu).
Unexplained Error during Solver Runs cfb CFX 6 November 9, 2012 16:42
Strange residuals of the Density Based Solver Pat84 FLUENT 0 October 22, 2012 16:59
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
