July 12, 2013, 05:50 |
Heat pipe simulation with phase change
Mohammad Bahreini
Rep Power: 14 |
Hi
i want simulate Heat pipe with openFoam,But i cant choose use better twophase solver for this! interfoam or twophaseEulerfoam or interphasechangefoam? guide me plz.. |
July 12, 2013, 17:53 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings mecman,
Can you be more specific of what you want to simulate? Best regards, Bruno
July 13, 2013, 01:53 |
Mohammad Bahreini
Rep Power: 14 |
Hi Bruno Santos
i want simulate heat pipe with two phase flow(vapor and liquid). operation heat pipe: a heat pipe is closed tube that filled of working fluid. At the heat source(evaporator) the cold liquid(working fluid) is evaporated, the hot vapor flow(with bubble) is afterwards transported to the heat sink(condenser) where the vapor condensates again and is transported back to the heat source. in this case we have heat and mass transfer.i want start work with interfoam solver but i dont know is good solver for this Plz Help T N Q |
July 13, 2013, 15:26 |
Bruno Santos
Rep Power: 128 |
Hi Mohammad Bahreini,
Ah, that's indeed a better description A bit of Googling lead me to this page: http://www.openfoam.org/version2.1.0/multiphase.php From that page, I believe the solver you're looking for is compressibleTwoPhaseEulerFoam. On that page it indicates which tutorial demonstrates how to use the solver. Best regards, Bruno
July 13, 2013, 16:23 |
Mohammad Bahreini
Rep Power: 14 |
Hi Bruno Santos
T N Q for reply you offer me, choose Compressible two phase Euler solver?this solver is new,and i dont have information of that..do you think best solver for my case? regard and very very T N Q |
July 13, 2013, 17:06 |
Bruno Santos
Rep Power: 128 |
As I said, from the description on that page, it seems to be the only solver that fits the description of your case. All other multiphase related solvers are either just for incompressible flow and/or cavitation and do not seem to take into account heat transfer. Therefore, unless you do not want to simulate the actual phase change between liquid and vapour states, then this solver seems to be the best suited. Best regards, Bruno
July 13, 2013, 17:56 |
Mohammad Bahreini
Rep Power: 14 |
Hi Bruno Santos
thanx for help me... |
September 8, 2013, 05:16 |
condensation and evaporation simultaneously
sasan
Rep Power: 13 |
Hi Burno and Mohammad
In youre opinion, can we have condensation and evaporation model in one solver? As Mohammad said, in heat pipe condensation and evaporation occur simultaneously, I simulate Heat pipe in Fluent with UDF code , but OpenFoam, I don’t know ….is it possible? |
September 8, 2013, 10:49 |
#9 |
Bruno Santos
Rep Power: 128 |
Greetings Sasan,
It's possible, but I'm not familiar with these solvers on OpenFOAM. It's very possible that you'll have to code a solver yourself, based on the existing solvers. Best regards, Bruno
February 24, 2020, 23:52 |
#10 | |
Ilhwan Yeo
Rep Power: 6 |
I want to simulate the same situation. but I want to add conjugate solver. Did you solve it? If you solve it, Could you help me? thank you. |
May 8, 2020, 04:42 |
#11 |
Rep Power: 8 |
hi, i want to simulate the flow boiling.can you help me?which solver can simulate the eavaporation ? thanks in advance
How to deal latent heat during phase change through source term udf | dkb_bg | Fluent UDF and Scheme Programming | 4 | April 12, 2018 21:26 |
heat transfer along a pipe | lysander | FLUENT | 0 | July 28, 2012 00:39 |
phase change modeling | Danial Q | Main CFD Forum | 0 | April 5, 2012 02:14 |
Phase change heat transfer | Lexa | FLUENT | 0 | October 10, 2011 03:53 |
two Phase column simulation | chemeng | OpenFOAM | 3 | August 18, 2010 13:53 |
