interRegionHeatTransferModel
Like Tree1Likes
  • 1 Post By Yann
Old   July 12, 2013, 11:46
Default interRegionHeatTransferModel
Nemanja Kliska
TheRealNemo is on a distinguished road
I am trying to create a heat transfer model using chtMultiRegionFoam. In this model I am trying to simulate a heater using a constant internal heating term. I looked into how other people have attempted to do this in OF1.7 but I think these threads are outdated as there has been considerable change to the solver.
I am only working with solid components so the solver for this section looks like:
fvm::ddt(betav*rho, h)
- fvm::laplacian(betav*alpha, h, "laplacian(alpha,h)")
fvOptions(rho, h)
I looked into adding a source term to the above equation, but it seems as though fvOptions has the capacity to act as heat source term using interRegionHeatTransferModel. Since this is a relatively new feature I cannot find any documentation or examples of how to implement this. I already looked at OF2.2 tutorials with fvOptions and turned up empty.
Has anyone here used, or has an example/tutorial of how to implement fvOptions::interRegionHeatTransferModel as a constant heat generation source.
TheRealNemo is offline   Reply With Quote
Old   January 22, 2014, 16:11
Michael Page
micpage18 is on a distinguished road
I'm facing the same problem.
Does someone have an example of interRegionHeatTransferModel as a constant heat generation source?
Thank you,
Michael Page
michael.page@simu-k.com
Simu-K inc.
www.simu-k.com
micpage18 is offline   Reply With Quote
Old   March 27, 2018, 02:13
Peter Hess
peterhess is on a distinguished road
Dear openFoamers,
This topic still for me unsolved.
How to add heat source to a given region?
Any idea?
Regards
Peter
peterhess is offline   Reply With Quote
Old   March 30, 2018, 11:30
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hi Peter,
You can add a heat source using fvOptions with the "scalarSemiImplicitSource". This is quite straightforward and you can use different selectionMode depending on what you want to do. (ie: using a cellZone to add a heat source in a specific volume inside your domain)
There are several posts on this topic, Check this one.
peterhess likes this.
Yann is offline   Reply With Quote
fvoptions, heat source
