libsimpleFunctionObjects: functionObject name
Like Tree2Likes
  • 1 Post By gschaider
Old   June 26, 2013, 09:10
Question libsimpleFunctionObjects: functionObject name
pad
PA
pad is on a distinguished road
I need to calculate massflow at certain patches for which I use libsimpleFunctionObjects.so.
However, when I specify the function object to be e.g.
_massflow
type patchMassFlow;
functionObjectLibs ("libsimpleFunctionObjects.so");
verbose true;
patches
inflow
ami_21_30
ami_40_31
outflow
ami_31_40
ami_30_21
factor 3600.0;
the data will be saved in a folder named patchMassFlows__massflow. Is there a way to specify that patchMassFlows_ should not be included in the name?
It might seem to be a small problem but my postprocessing script relies on every functionObject to be saved under _<NAME>.
Regards
Per
Regards,
Per
pad is offline   Reply With Quote
Old   June 26, 2013, 12:37
Assistant Moderator
Bernhard Gschaider
_massflow
type patchMassFlow;
verbose true;
patches
inflow
ami_21_30
ami_40_31
outflow
ami_31_40
ami_30_21
factor 3600.0;
Regards
Per
Currently the hardcoded behaviour (to change it you'd have to go to the source) of the simpleFunctionObjects that write data is to compose the folder name from the type name and the FO-name. To make matters worse the latest release writes these folders to a sub-folder "postprocessing" (convention since OF 2.2)
Short answer: No
pad likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 27, 2013, 03:16
pad
PA
Hi Bernhard,
Thank you for your reply.
I don't like to modify the source code unless absolutely necessary so I guess for now I will modify my postprocessing scripts slightly.
Is there any particular reason for adding the typename in front of the FO name as this doesn't seem to be standard OF behaviour (at least in 2.1)? Or have I misunderstood something here?
Thanks again...
Regards,
Per
Old   June 27, 2013, 07:20
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
Thanks again...
Well. Reason. Similar to yours:
- Scripts. Mine say "Ah. 'patchMassFlow_*'. I know how to handle that"
- It is easier to remove files. "rm patch*" throws away all the patch-stuff. I don't have to look around "Err. 'fooFlow' is what? Ah. patchMassFlow. OK. Let it go"
So basically the types were added to the directory names because I think that redundant information makes life easier
pad likes this.
functionobject, massflow
Create registered object at runtime using a functionObject CedricVH OpenFOAM Programming & Development 21 November 28, 2012 06:04
runTime out of scope in functionObject Sune OpenFOAM Programming & Development 2 September 26, 2012 03:11
functionObject file format akidess OpenFOAM Post-Processing 7 February 24, 2012 09:51
Access particle data from functionObject CedricVH OpenFOAM 10 July 21, 2011 13:03
Process control functionObject Vetter OpenFOAM 4 January 14, 2011 11:38
