Simple heat transfer in tube case
Like Tree2Likes
  • 1 Post By Gimlas
  • 1 Post By Gimlas
Old   June 26, 2013, 08:17
Default Simple heat transfer in tube case
Gimlas is on a distinguished road
Dear Forum Users,
I would like to ask you for your help with a simple case of air cooling in a pipe. The geometry i very simple: it's a pipe of a diameter D which narrows to a smaller diameter and then goes straight up. I can't upload the mesh file due to its size which results from the viscous layer on the walls. But you can assume that its a simple straight pipe. Warm air (238 K) enters through the bottom inlet and it flows out through the top outlet. Meanwhile it is cooled by cold walls (283 K).
I am learning how to prepare a simulation in openFOAM therefore I try to modify existing cases. In my calculation I've used the tutorial case of buoyantBoussinesqSimpleFoam hotRoom. All modified files are attached to this post. Unfortunatelly I do not understand some of the code therefore I had to improvise.
For the initial conditions I have generated velocity field U using potentialFoam (in other case the calculations of p_rgh crashed after few iterations). The oryginal U file is also attached.
But I have encontured a weird problem. Everything looks fine except the outlet where static pressure fluctuations appeared. The boundary conditions for outlet is set to 0. However there are small regions wher this pressure goes below 0 Pa and there is no reason for that. I have followed an advice from this forum and changed the boundary conditions for:
    Outlet
        type            fixedMean;
        meanValue       0;
        value        uniform 0;
But the results didn't change. There are still pressure fluctuations (small regions which drops well below 0 Pa).
I have made a similar simulations without heat exchange using SimpleFoamWizard from CAELinuks and everything looks normal.
Could you help me to solve this problem?
rajcfd likes this.
Gimlas is offline   Reply With Quote
Old   July 2, 2013, 08:52
Dear forum users,
I have managed to enhance some of the boundary conditions but still there is one problem that has to be solved, i.e. static pressure. All parameters are predicted properly:
- p_rgh
- U
- T
The pressure difference between inlet and outlet seems to be ok to. But my intention was to set the static pressure at the outlet (pipe top) to 0 so the openfoam determine the overpressure at the inlet (bottom). Dou you have any ideas how to achieve that? I'm attaching new case files and contour graphs.
ScarFace likes this.
Old   July 2, 2013, 15:05
cfdonline2mohsen's Avatar
Mohsen KiaMansouri
cfdonline2mohsen is on a distinguished road
Dear Gimlas
I quote the section 4.5.3.1 of the user guide
4.5.3 PISO and SIMPLE algorithms :
In a closed incompressible system, pressure is relative: it is the pressure range that matters not the absolute values. In these cases, the solver sets a reference level of pRefValue in cell pRefCell where p is the name of the pressure solution variable. Where the pressure is p rgh, the names are p rhgRefValue and p rhgRefCell respectively.
you can fix your reference value for pressure in system/fvSolution inside your case folder.
just add the two below lines inside PIMPLE (or PISO):
pRefValue           0;
pRefPoint           (1.3 0.15 0.325) //the coordinates of your outlet
see the user guide for more help.
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.”
cfdonline2mohsen is offline   Reply With Quote
buoyantboussinesq, heat exchange, open foam, pressure boundaries
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 05:07
simple heat transfer problem openfoam1 OpenFOAM 2 January 27, 2010 15:17
Heat transfer in tube bank. Paul FLUENT 0 August 6, 2004 11:05
Heat Transfer Validation test case Chris Whitney Main CFD Forum 1 July 21, 1999 15:36
