How to Initialise my LES case using my RANS case is there any utility for it ?
Like Tree1Likes
  • 1 Post By adambarfi
Old   June 11, 2013, 12:12
Question How to Initialise my LES case using my RANS case is there any utility for it ?
Alhasan's Avatar
Hasan K.J.
Alhasan is on a distinguished road
Hey All,
Can some body tell me how to initialise one case using another case in openFOAM, say how to initialise a K-omega case using a K-epsilon case !!!! - answer to this is more than enough.
but if u know LES then actually I am trying to initialise my LES case using my RANS case i dunno where to start with, can i just copy paste my U file from the RANS case to my LES case im not sure that is right
- can somebody who has done it please tell me because my LES case without intialising the Courant number goes high and crashes so this is my only option and i dunno how to go about it
Thanks guys
Hasan K.J
Alhasan is offline   Reply With Quote
Old   March 26, 2014, 13:53
vut
vut is on a distinguished road
Hi Alhasan,
I am interested in this topic too. Do you have some advices to share?
Thank you,
vut
vut is offline   Reply With Quote
Old   May 10, 2014, 01:14
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
hi,
first, run your case with RANS and then:
- Control dict, changing simulation to pisoFoam and verify you're not going to have problems with your timeStep. I'm using a Courant Number of 0.05, with Co=0.5 my calculation diverged for instance.
- You have to change "fvSchemes" and "fvSolution" as I wrote the other day. The motorbike tutorial files work well.
- You have to add "nuSgs" and "nuTilda" to the startTime of the LES simulation which will be the endTime of the RANS simulation, and in my case I erased "nut".
- If you're running a parallel calcul you will have to add "proc.*", you can find this in the motorbike tutorial too.
- Finally, you will have to change the constant folder too. You must erase the "RASproperties" file and add "LESproperties" and "turbulenceproperties", you can find both of them again in the motorbike tutorial.
you can use mapFields if your geometry or BCs are different with your new case.
Alhasan likes this.
adambarfi is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Help! Should I use LES in this case. Thanks. Feng FLUENT 4 April 25, 2008 18:04
Mapping RANS data onto an LES christian OpenFOAM Running, Solving & CFD 0 April 13, 2007 06:31
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
use of common RANS B.C.'s in LES? Sanjin Saric Main CFD Forum 0 March 21, 2002 07:08
