Flow over an airfoil using Realizable K Epsilon |
June 9, 2013, 13:09 |
JP
Rep Power: 13 |
Greetings Foamers!
I am simulating a symmetric airfoil with a Reynolds number of 6,000,000 million and a zero angle of attack in OpenFOAM. The flow velocity is 87 m/s with standard density and kinematic viscosity (also the chord of the airfoil is 1 m). I am using the realizable k-epsilon turbulence model but I am struggling a bit with it. I have simulated this same airfoil at the same conditions using Spalart-Allmaras and SST and the results I got were close to experimental/computational results. The mesh worked with SA and SST although it has very high aspect ratio cells on the wake of the airfoil. Just as an example of how 'crappy' the results are, I have attached the residuals for 1st order upwind. k and epsilon seems to oscillate a lot. I am not using wall functions because my mesh is very fine near the wall (approximately achieves about a wall y+ of around 0.2). Instead I am imposing a zeroGradient BC on the wall for k and epsilon. The boundary conditions for k, epsilon and nut were computed using the following relations from Spalart and Rumsey: nut = 2e-7 *U k = 1e-6 *U^2 epsilon = 4.5e-7*U^3 I don't know exactly what is going wrong with this case. It may be the fvSchemes I am using. In general, just to be safe, I run calculations for a few iterations with Code:
div(phi,U) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,k) Gauss upwind; Code:
div(phi,U) Gauss linearUpwind grad(U); div(phi,epsilon) Gauss linearUpwind grad(epsilon); div(phi,k) Gauss linearUpwind grad(k); Could anyone look at my case and point out possible mistakes or things a more experience user would do? https://www.dropbox.com/sh/krabswgrufc2cm4/bP7FCRefq4 Thank you very much for the help! James |
June 10, 2013, 03:09 |
Niels Nielsen
Rep Power: 27 |
Hi
First off if these the correct dimensions of the mesh Code:
Overall domain bounding box (-484.457 -1 -507.806) (501 0 507.806)
Linnemann PS. I do not do personal support, so please post in the forums. |
June 10, 2013, 05:17 |
#3 | |
JP
Rep Power: 13 |
Yes that is the domain. It is a NASA validation case, and the domain lenght is about 1 km long 9they did that to avoid any interference with the domain boundaries). That should not be a problem however because I have been simulating this case succesfully for the SA and SST models. Furthermore, I used the same settings I posted for the airFoil2D tutorial and I got the same 'crappy' results. As I said, there has to be something wrong with the numerical schemes or with the boundary conditions, but as far as I am concerned, the BCs I am using are pretty standard. I am aware that k-epsilon turbulence model is very tricky when it comes to the epsilon equation... Can you see anything fundamentally wrong with my set up? Thank you for your help! James |
June 10, 2013, 06:31 |
Felix L.
Rep Power: 18 |
Hello James,
The realizable k-e-model in OpenFOAM is not a low-Re turbulence model. Therefore, you can not use it without wall functions. This is the reason why your results are bad. Use the low-Re k-e-models implemented in OpenFOAM if you want to try out this class of turbulence models. Greetings Felix |
June 10, 2013, 06:42 |
JP
Rep Power: 13 |
Hi Felix,
I will give it a shot. I will use the Launder Sharma turbulence model. My only question now, is why can't I use the realizable KE turbulence model without using wall functions even if I am resolving the entire BL? Thanks, James |
June 10, 2013, 08:21 |
Felix L.
Rep Power: 18 |
Hello James,
epsilon based turbulence models become unstable and yield unphysical results when integrated down to the wall through the viscous sublayer. The only way to overcome this is either to use wall functions (-> High-Re models) or to add damping functions into the turbulence model (-> Low-Re models). For more details, please read Turbulence Modeling for CFD by D.C. Wilcox. Greetings Felix |
June 10, 2013, 12:41 |
JP
Rep Power: 13 |
Hello Felix,
So, I have tried to simulate the case using the LaunderSharma turbulence model. The residuals for the first order case look pretty good as it can be seen. I would like to point out that I had to change the fvSolution from what I posted earlier to: Code:
p { solver PCG; preconditioner DIC; tolerance 1e-16; relTol 0.001; } U { solver PBiCG; preconditioner DILU; tolerance 1e-15; relTol 0.001; } k { solver PBiCG; preconditioner DILU; tolerance 1e-8; relTol 0.001; } epsilon { solver PBiCG; preconditioner DILU; tolerance 1e-8; relTol 0.001; } Any suggestions? Thanks for the help!! James |
June 11, 2013, 06:35 |
Felix L.
Rep Power: 18 |
Hello James,
your boundary conditions are wrong. At the wall k and epsilon both equal zero, when using Low-Re models. See, e.g., http://www.cfd-online.com/Wiki/Low-Re_k-epsilon_models Usually its better to set those quantities to low nonzero values, for example 1e-16. This avoids div by zero errors. Greetings Felix P.s.: this information is also found in the book I mentioned. So I strongly advise you to read it, if you want to work with the different turbulence models. |
June 11, 2013, 06:59 |
#9 |
JP
Rep Power: 13 |
Thanks Felix,
I somewhat got confused with other post that recommended using zero gradient. Also I tried setting there k and epsilon to zero but it would give me a floating point exception (due to the singularity in epsilon equation)... I will try to take a look at Wilcox but it is not a easy book to find ! Will try these settings! Thanks for the help, James |
June 11, 2013, 14:13 |
#10 |
JP
Rep Power: 13 |
Hi Felix,
yet another question about this !!! I implemented all the changes you suggested and now k and epsilon are zero in the wall (k, epsilon = 1e-16). I presume the rest of the boundary conditions are correct since they have remained untouched from the SST simulations I was able to complete succesfully a while back. The changes however do not improve the convergence at all, and even for Gauss Upwind schemes I see no signs of convergence (the pressure residuals do not drop at all). I simulated the airFoil2D geometry with the same settings and it appeared to work very well. Now I have no idea of what could be wrong with the set up! Thanks, James |
June 12, 2013, 04:42 |
#11 |
Felix L.
Rep Power: 18 |
Hello James,
it's probably the tolerance settings for k and epsilon. As you can see in the residual plot, these quantities "converge" very quickly and OpenFOAM doesn't solve those equations anymore after a few iterations. However, residuals of order 1e-8 don't necessarily mean that the k and epsilon fields are correct, since they depent on the flow field which still is being solved. Reduce the tolerance for k and epsilon to something like 1e-16 and see if it helps. Greetings Felix |
June 12, 2013, 08:29 |
#12 |
JP
Rep Power: 13 |
Hi Felix,
As far as I am aware, I have the tolerance of every quantity set to 1e-16. Furthermore for k and epsilon I have a minIter of 1 (I don't know if it works though but I assume it does because I don't get any errors). Could it be the reltol? Thank you, James |
June 12, 2013, 09:16 |
#13 |
Felix L.
Rep Power: 18 |
Hello James,
post #7 tells me something different about your tolerance settings? I really mean "tolerance", not "relTol". Also the residual plot confirms the 1e-8-setting for k and Epsilon. minIter doesn't work in the official OpenFOAM distributions. It has no effect. Greetings Felix |
June 12, 2013, 16:14 |
#14 |
JP
Rep Power: 13 |
Hi Felix,
Well I hate to say this but I seem to be (still) struggling with this. So I implemented all of your suggestions and the solution does not converge at all even using 1st order upwind. I have revised the BCs over and over and, as long as I am aware, they should be correct now. I have also tried different numerical schemes and relaxation factors and they did not improve the situation. Furthermore in some cases I even get negative drag values, which bothers me a lot. I have re-checked the mesh and it is the same mesh I used for SA and SST (which worked just fine)... I am not able to see anything really wrong with my set up. I attached it, in case someone wants to take a look at it. Recommendations are welcome! Thank you very much for your help! James |
June 14, 2013, 08:46 |
#15 |
Niels Nielsen
Rep Power: 27 |
Hi
Been trying to get your case to run with my usual tricks. Nothing so far works and I always trace the problem to the same Cells in the mesh. I have no solution to this problem.
June 14, 2013, 08:57 |
#16 |
JP
Rep Power: 13 |
Hi Linnemann,
yeah I have been working on it a lot and I don't seem to be able to find a solution either. It is very weird because that same mesh worked on SA and SST. Obviously the problem may be due to the fact that K-Epsilon is more sensitive to BCs near the wall than the other two turbulence models. Thanks for the help James |
June 14, 2013, 09:16 |
#17 |
Niels Nielsen
Rep Power: 27 |
Hi again
decided to try one more time and being really radical with the relaxation factors so I started out with. Code:
U 0.3; k 0.01; epsilon 0.01; Code:
U 0.3; k 0.1; epsilon 0.1; Code:
U 0.4; k 0.1; epsilon 0.1; Code:
U 0.4; k 0.2; epsilon 0.2; Code:
U 0.4; k 0.3; epsilon 0.3; Code:
U 0.5; k 0.3; epsilon 0.3; Code:
U 0.5; k 0.4; epsilon 0.4; The residuals are really not stable and the forces are fluctuating quite a bit. But it runs and it does not crash and the velocity looks reasonable
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 10:26 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 05:55 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 21:21 |
Laminer and turbulant airfoil flow | M. Essuri | FLUENT | 3 | November 3, 2006 15:14 |
Simulating flow past airfoil with different AOA | Quarkz | Main CFD Forum | 2 | January 6, 2006 11:56 |
